Computer makes beeping noise
I recently changed the computer to a different place in me house and connected to an outlet that is linked to a light switch, My kids as well as myself keep forgetting that the switch would turn the computer on and off as well. Oops!! now it turns on but makes beeping noise and then the it reads for the recovery disks on the monitor screen. maybe something burned?? please help!
  • 8,404 Answers
The beeping is telling you something ... counting the beeps and matching that to the make and model on a beep decoder would answer your question.
What are you going to do about the switch controlled outlet? Id suggest you run a power strip from another hot all the time outlet. It is a death sentence to continue to shut your computer off with first warning it.
I hope this helps you
a
Posted on Sep 30, 2009
Beeping noises
One thing you could try is take the drive out of the housing and place it inside your computer.
Oct 09, 2012 | LaCie 500GB Rikiki USB 30 Black
I accidentally change my mac address in the router... now i dont have internet connetion..... how can i change it back... w/o accessing in the internet.... please respond...
If you are connecting the router to a cable DSL satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem's power adapter. Shut down your computer.3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the WAN port on the router.4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.7. Turn on your computer.8. Verify the link lights on the router. The power light, WAN light, and the LAN light (the port that your computer is plugged into) should be lit. If not, make sure your computer, modem, and router are powered on and verify the cable connections are correct.9. Skip to page 16 to configure your router.Connect to Cable/DSL/Satellite Modem OR
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having ftp://ftp.dlink.co.uk/dir_products/dir-600/manual/DIR-600_B2_Manual.pdf
Aug 27, 2011 | D-Link DIR-600 Router
I have a verbatim 320GB externam hard drive the model is CLON320GB. One day it just stopped registering on the computer. At first it woulod make a constant beeping noise when I plugged it in but would not...
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
Jul 13, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
Power button
You have faulty motherboard my friend.Time to get new laptop as it is expensive to change mb
Nov 18, 2009 | Dell Latitude D600 Notebook
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Computer turns on and beeps
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
Mar 13, 2009 | Microsoft Windows XP Professional
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
D-Link Wireless Router DIR-625 unable to connect with D-Link DWA-130 adapter
Sometimes the security settings will only let certain MAC addresses connect to the network as well as the password protection. Make certain that yours isn't filtering out MAC addresses.
Aug 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
RD480-1939 2 post beeps
This document is intended to help users who are experiencing issues with the POST and may have any of the below symptoms.
  1. Computer beeps irregularly when the computer is turned on.
  2. Computer turns on but does not boot.
Note: Not all computers have beep codes, some of the newer computers have LED's that light up that indicate the error or have a sound file to indicate the error.
Cause: This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Answer: Warning: Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.) then this issue is not a NO POST but is an power related issue see document CH000312. Remove new hardware If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.
Disconnect external devices Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs.
Identify beep code If you are receiving a sequence of beeps see our beep code page for a listing of different beep codes and their explanation and/or your motherboard or computer documentation. These beep codes are meant as a method of quickly identifying what computer component is failing or bad.
Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable.
  • All disk drives should have a data cable and power cable connected to them.
  • Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans.
Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST attempt to disconnect the Riser board (if applicable) and/or each of the expansion cards. If this resolves the issue or allows the computer to post connect one card at a time until you determine which card is causing the issue.
Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect the IDE, SATA, SCSI, or other data cables from the CD-ROM, hard drive, and floppy drive from the Motherboard.
If this resolves your irregular post or you now get an error message attempt to re-connect each device one at a time to determine which device and or cable is causing the issue. In some situations it can also be simply a loose cable connection that causes the issue.
Remove the RAM If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply and/or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot.
This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware.
Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer.
Bad motherboard, CPU, RAM, and/or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have bad Motherboard, CPU, and or RAM. The next step would be either to replace these components and/or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order and/or try swappable parts from other computers.
Nov 21, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Car charger lights up but phone does not take charge
try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Oct 08, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
