Question about Jensen XA4100 Car Audio Amplifier
I have a Jensen XA4100 amp and would like to know the high input pin connection positions
  • ypb3333 Oct 02, 2009
    got the info thanks guys this site is great
    Paul
5 Suggested Answers
  • 113 Answers
SOURCE: Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Posted on Aug 22, 2007
etirbynnor
  • 655 Answers
SOURCE: PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
Posted on May 24, 2009
  • 13 Answers
SOURCE: Need to know what connections for 6 pin input port
Unless your using an old school radio, your radio should have RCA Jacks.. Use them, not the factory wiring..
Posted on Jun 21, 2009
  • 70 Answers
SOURCE: Jensen XA 2100 Amp. Need
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Posted on Aug 03, 2010
Can u hook up a model XA184 without 16 pin connector using r c a jacks on other side
Yes. The 16 pin (high level) inputs are ONLY used if you do not have RCA inputs running to the amp. If you have both, ALWAYS only use the RCA'S for best sound.
Dec 08, 2013 | Jensen XA92 Car Audio Amplifier
I just bought a Jensen vm9215bt head unit. And I do not know how to hook up my subwoofer. I have three cables coming from my amp. I have one of them so the amp will turn on, I have that one connected. But...
Most amplifiers have a common color code to hook them up. On your head unit, there should be a blue wire. That is your amp. Turn on lead. The positive + symbol goes to your battery +. And that lead is usually red. Your negative terminal - is this symbol and the wire s usually black. That either goes to the - side of the battery or grounds to car chassis. The sound inputs to your amp. either by RCA cables or high speaker level input. That depends on your amps. set up. If you have any questions, post back and I'll try to reply by next day or two.
Oct 02, 2013 | Car Audio & Video
How to get amp out of safe mode
first check all connections, fuses and speaker wiring. Check to make sure that the amp is getting enough power to keep it running, meaning a piece of 4 to 8 gauge minimum wre from your battery to the amp. Make sure no wires are touching ground on the speaker outputs all the way to where they connect to the speakers. You can check this with a Ohm Meter to see if their is a direct short to ground. Or unhook all speakers and 1 by 1 touch them onto the amp to see if it cuts out. If the amp is going iinto protect mode without any speakers hooked up to iit (I have a bad keyboard sorry for the extra or missiing I's) and all other things I mentioned are OK then your amps bad and needs to be serviced. Hopefully It's just be a shorted speaker or wire.
Aug 07, 2013 | Jensen XA4100 Car Audio Amplifier
I dont know where the positive and negitive input is on the high input
AT THE CONNECTION INPUT SLOT FEMALE PORT THE UPPER AND LOWER PINS IN THE CENTER AND BOTH NEGITIVE AND ARE A COMMOM NEGITIVE CONNECTION POINT THEOUTER PINS TO BOTH SIDES ARE THE POSITIVE CONNECTION PINS 4 TO EACH SIDE OF THE NEGITIVE CENTER PINS THIS IS PROVEN EASY WITH ANY OHMS METTER THE UPPERNEGITIVE SUPPORTS THE UPPER POSITIVE INPUT OF HIGH INPEDENCE INPUTS
Sep 28, 2011 | Nitro BMW-483 Car Amp
Jensen XA 2100 Amp. Need High Level input plug diagram. In other words need to know what each of the 6 pins connects to.
Jul 30, 2010 | Jensen XA2125 Car Audio Amplifier
I have an older model Jensen 500 watt 2 channel bridgeable amp. When i hook it up the red light(protect light) comes on and it will not work
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Dec 01, 2009 | Jensen A300HLX Car Audio Amplifier
I have a jesen ka5 5channel amp plus mono and i dont know how to hook up the subs to the mono
Ok, you're going to choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps.
Oct 01, 2009 | Jensen Car Audio & Video
Hello gmb_66,
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Jensen XA4100
Aug 18, 2007 | Jensen XA4100 Car Audio Amplifier
JENSEN XA 184 AMPLIFIER
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
Jensen XA4100 Car Audio Amplifier Logo
76 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
