Question about Boating
I can't get any spark to the plugs on my 40 horse Tohatsu outboard. The motor has been sitting unused for about 5 years. Brad
    Problem Solver:
  • 12 Answers
Check your kill switch. Spark comes out of the stator, then to your coils
Posted on Oct 08, 2009
I have a 1995 25 horse tohatsu outboard and would like to us a fuel additive cleaner what do you think
a quality injector will be ok
to avoid problems do not use any e-mix fuels as the ethanol content attracts moisture that gives you fuel and injector problems
Jul 11, 2017 | Cars & Trucks
What year is Tohatsu M15B2 serial number 351A33838 outboard
Hi!
You can contact Tohatsu directly using the form provided at the link below.
Hope this helps,
-Steve
http://www.tohatsu.com/contact/wiz_modelyear.html
Aug 06, 2014 | Raymarine St6002 Smartpilot Hydraulic...
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
What year model is a mercury outboard 4 horse with serial number 3303712?
call a mercury dealeris all I can tell you .we handled johnson /evinrude.
Jun 17, 2014 | Light Outboard Motor Boat Bass Fishing...
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
My tohatsu 35N is missfiring when idieling other wise runs grate plugs are new thanks
Ensure you run the recomended fuel mix.100 to 1is what most modern engins run on. Read the manufactures instructions, sometimes on the cowl.
Cheers, Timo
Apr 21, 2010 | Light Outboard Motor Boat Bass Fishing...
Skipping, lack of power, 4 stroke mercruiser
has your boat been sitting more than 60 days. ethanol gas has been proven to only stay stable for 30 days in 90 degree + weather. Labor cost can be up to $100.00 per hour. CHEAP TEST- compression, spark, and fuel. TOOLS(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. TROUBLESHOOTING (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Sep 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
247 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
