Question about LG KM900 Arena Cell Phone
Cant answer phone when ringing, screen goes blank. also when dialing a number, press call, screen also goes blank until disconnect
  • farhan Sep 01, 2013
    only remove the screen sticker from the uper side of lcd then you will be able to answer the call
Shake ur phone.. simple
Posted on Oct 05, 2009
  • yangdesg Oct 05, 2009
    shake ur phone really simple
Why does my phone only rings once, calling party hears a couple of rings and then goes to voicemail. goes to dial tone when answered after first ring.
Press menu, go to settings then scroll down to ring count and set number of rings before it goes to voice mail.
Jul 18, 2014 | Panasonic Lands Phones
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Exact same problem.
Is this a system phone?
It sounds as though your set is not programmed with a line appearance. and line preference is not set, this can be set for intercom, or a line or nothing when you pick up the phone. You can do a pick up code to answer until an appearance is programmed on your set.
Aug 05, 2009 | Lands Phones
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Sound going in & out
What is happening is that she is accidently pressing the "up" portion of the rocker switch on the left side of the phone when she flips the phone open. You will notice (try this on purpose)that when you open the phone while holding the rocker switch up, that there are no key sounds when dialing a number. Oh yes, the number will dial and even show connected on the screen--but no sound!!!. Now, to hear the dialed number ringing, you must press the speakerphone button below the rocker switch. You don't have to turn on the speaker phone, just pressing this button restores sound. On the next call however, the sound will STILL not work until you press the 4 way toggle button in the center of the phone. Now the phone is restored to normal status. It took me about five hours and a million combinations of buttons to figure this out. See my post, from 121212. thanks tylervance1@yahoo.com
Sep 30, 2006 | Motorola Mobility E815
LG KM900 Arena  Cell Phone Logo
265 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
