Question about iLO MP3 Player
I received beats (tracks, music) because I am an artist from zip files which I downloaded took forever....I cannot burn it to a CD because its is in wave format...How do I turn it to MP3 format So it will be compatible with windows media player. Im stumped. Thank you.
  • mart6551 Sep 30, 2009
    You The Man!!!
  • 341 Answers
Try a software called TuneConvert, a free converter that converts any music format to MP3 or AAC.
http://download.cnet.com/TuneConvert/3000-2140_4-10921332.html?tag=mncol;pop
Hope this helps!
Posted on Sep 30, 2009
How can I get track names on wave bose
When you make a cd if the names are not coming in when you add the tracks you can try a feature on most programs which is called get track names or something similar if this does not work you can type them in manually most burning programs have the ability to do this . I have all these features on my burning programs . You would have to import the tracks into a new play list and try what I said bottom line is at the least you should be able to add the track names manually then burn and they will show up on most radios or CD players . Hope this helped
Sep 03, 2014 | Bose & Wave& Music System
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Whenever I put songs in my RCA MP3 player from blank cds, the organization gets immensely messed up, forcing me to start all over from scratch (0 music). Why? Or how can I fix this?
It could be that your RCA MP3 player is sorting the MP3's by track number. By this I don't mean the track number in the file name of the MP3 but in the "MP3 tag". There's a portion of every MP3 file that allows the file to contain lots of data other than the sound. It contains things like Album, Year, Artist, Title, Composer, Genre, etc. It's likely that the RCA MP3 player is reading the "Track Number" field of the MP3 tag for each MP3 file. You can download a free program called MP3Tag at http://www.mp3tag.de/en/. It will let you specify the track numbers for each MP3. See if setting each file's "Track Number" allows you to sort the order on the MP3 player.
Dec 16, 2011 | RCA Audio Players & Recorders
I want to put music on my eclipse mp3 player 180SL 4g. I have CD's. Please HELP. I am a performance artist and I need to practice in preparation for an upcoming event.
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 25, 2011 | Audio Players & Recorders
I want to download my music off of itunes and put it on my sons mp3 player but its not working
i tunes and mp3 players are not compadable. i tunes is strictly for apple products(ipods) 2 download music to mp3 player, you would have to download music from ur pc from limewire or something like that. it will then copy to ur windows media player library and be ready to sync mp3 player.. good luck
Dec 11, 2009 | Audio Players & Recorders
How do i import the tracks from a cd to the track board?
i tried everything to import my rap beat into my tascam 2488 neo it wont let me says that i want a anotrher cd
how do i know which cd to put the wave file in cuz all i did were convert the beat into wave file in itunes and burn it as data on the cd and it wont do it i also burn it as music on the cd it wont do it what do i do?
Jul 25, 2009 | Tascam 2488 Portastudio Multitrack...
WMA/MP3 Playback will not work
This may be a problem with the internal software within the pioneer device. Try burning your music using the wav extension. these files are larger than the mp3 but, this should play well. you may need to try an updated version of the burning software you are using as well. this could be the problem.
Jan 27, 2009 | Pioneer DEH-P840MP CD Player
Downloading cd/album cover to ipod when downloading the music
your doing nothing rong if your divce can,t find a artis or cover this is the next thing it will do but if you use itunes set to manule load you can right what you like in
Jan 23, 2008 | Apple iPod nano 3rd Generation
Burning CD's - I want to write personalized Text and be able to read it on my CDJ's
Not sure if Nero allows this. I'm sure it does, but with so many anti-piracy lawsuits going around, alot of CDR software manufacturer's are sticking to whatever the RIAA tells them they can and can't offer to their users.
I know iTunes let's you change the artist name as well as the CD cover/image. In Nero, do a search in help, and search for ID3 tags or ID3V tags.
Here's some info on ID3 tags from Wikipedia.
- TWEAK A/V LAB
Nov 12, 2007 | Pioneer CDJ-800 Turntable
18 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
