Question about Compaq Presario CQ50-215NR Notebook
The compaq cq50 is indeed a problem for some people that i have seen, i had one an the motherboard,cpu, a the hard-drive was blown, under warrenty it was fixd. but if i was anyone that has this model i would get brand new after market parts an hang on to them for that just in case moment
    President:
  • 2,600 Answers
I think this goes for most Hp models in the DV and CQ series....good thing parts are plentiful.
Posted on Sep 30, 2009
A continous beeps when turning on the computer. i have to press the fn key to start loading the windows
one continous beep could mean a bad connection / loose lead
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the cpu make sure it has dust free secure seating
also check your computer ram modules to make sure they are dust free and securely seated
hope this helps you
Oct 30, 2011 | HP Compaq Presario CQ50-130US Notebook
I have a Compaq CQ50-210. Problem with the HP COMPAQ Presario CQ50-210US NoteBook AMD Athlon X2 QL-62 15.4' Wide XGA 2GB Memory 160GB HDD... I have a Compaq CQ50-210. When I try to boot it, the screen...
Power up the external monitor first and then boot up the laptop, the video info will automatically divert to the external monitor.
If you do not see a Windows image on the external monitor then it is definitely a motherboard issue, because the video card is built in on the motherboard.
The Video card uses shared RAM (part of the RAM module/s ), try re-seating the RAM modules, also test the RAM modules.
You can test the hard drive by removing the hard drive and connecting it to an USB hard drive adapter, then connect the adapter into a working computer's USB port. If the hard drive is OK, this computer will see it as an external storage device and you can open the various folders and files on the hard drive.
Dec 12, 2010 | HP Compaq Presario CQ50-210US Notebook
I neet dounload driver CQ50 Cpu AMD Athlon-2X 64
If you're looking for drivers for your laptop go to this compaq support site and click "Software and driver downloads". From there select your version of Windows and click the red "next" button. There will be all your drivers listed for you.
Jun 08, 2010 | HP Compaq Presario CQ50-140US Laptop
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
MY COMPAQ PRESARIO NOTEBOOK CQ50 100EM - DOES NOT
The issue might be with the hard drive. I recommend you to test the hard drive.
If the hard drive test fails, then it is confirmed that the issue is with the hard drive of your notebook.
Click on Testing a hard disk in HP notebooks in the below link to test your hard disk:
http://notebook-solutions.blogspot.com/2009/06/all-about-hard-disks-in-laptops.html
You may also try the steps in the below links:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=23287&lc=en&dlc=en&cc=us&product=3752686
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops
Jun 27, 2009 | Computers & Internet
Ticking Sound
I just checked the HP site and it looks like it is indeed the cooling fan. The cooling fan is on the left-hand side with the vents under the left rear side. Check the screws, one or two may be loose. Also, something may have come loose on the inside so be prepared to open the entire thing and check for something that the fan blades are hitting.
Jan 27, 2009 | HP Compaq Presario CQ50-130US Notebook
Compaq Presario CQ50-215NR Notebook Logo
269 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
