Question about Dishwashers
Soap dispenser no longer totally empties. - Dishwashers
  • frlang Sep 30, 2009
    guess I'll have to give it a try.
    Genius:
  • 1,341 Answers
Depending on models,some of them build up a deposit over time at the bottom and some are underneath the soap dispenser.You will need some warm water and give it a good clean with a brush.Also look around the top where the dispenser fits into the unit, sometimes there is deposit to the spray unit from the top which gets clogged up over time and hence stops waters from sprinkling into the dispenser. An all round good cleaning will solve this problem.
Posted on Sep 30, 2009
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Dispenser working but had new granite counter installed and it is now thicker. Need a longer shaft to screw soap dispenser on u der sink
Take both pieces to hardware store they may have the top only. If not, they sell soap pumps made for granite counters.
May 09, 2012 | Moen Soap & Lotion Dispenser 3910S
Hi, I have a Fisher Paykel DD603I (integrated) dishdrawer unit. The bottom drawer soap dispenser has water in it after it runs (and leftover soap), and there is a small amount of water sitting in the...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 16, 2011 | Fisher and Paykel Dishwashers
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
Soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
How do I make sure the dispenser is completly empty?
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Jul 21, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Apr 05, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
