Question about Denon AVR-2106 Receiver
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
  • 151 Answers
SOURCE: Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
Posted on Jul 12, 2008
  • 139 Answers
SOURCE: Denon AVR-2309ci receiver keeps losing power after a few seconds
This is a defective unit. bring it back to best buy and have them replace it.
Posted on Jan 02, 2009
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
  • 5 Answers
SOURCE: While watching tv my speakers started cracking and
I had the same issue..I called Denon support and they fixed the problem. You need to reboot the micro-processor....turn off the unit...hold down A+B then turn on...the display blinks (all the display is illuminated) Let go of the buttons.....issue resolved!
Good luck....
Posted on Mar 09, 2010
  • 675 Answers
SOURCE: as soon as the speakers
Sounds as if you may have a bad speaker component that is causing the unit to go into a protection mode to protect the unit from shorted speakers/outputs. Try to unplug the speakers entirely and then turn on the unit...If it still does this and goes into standby with the speakers disconnected then there is a problem probably in the audio amplifier circuit that will need servicing by a technician. If the unit stays on..then I would try to put different speakers on the unit to see if it works..if so, then suspect your speakers...if not , then suspect the receiver
Posted on Jan 06, 2011
0 characters
1 Points
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Jan 07, 2011 | Denon AVR-1709 Receiver
How can I get my Denon 2106 to play through my television? I'm not sure what's happened. I feel like I have the cables hooked up properly. It's worked for years. My stereo plays, so it's not the speakers....
Hello: If you are trying to get the sound from the TV to come through the receiver to your speakers and are hearing nothing, I had the same problem. For some reason, and I have the question posted, the sound level requirement is much higher for the TV. I turned my receiver up to +2 decibels and the sound was there. However, if you play high def channels through the receiver, the +2 will blow your ears off. My new problem is why does the regular TV need so much volume on the dial while the high def channels only require the lower sound level. It prevents you from switching from regular to high definition channels. So, in summary, the sound is there, just turn the volume way up.
Oct 30, 2010 | Denon AVR-2106 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Jan 02, 2009 | Denon Audio & Video Receivers
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Jul 23, 2008 | Denon Audio & Video Receivers
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
Avr receiver
More than likely audio o/p problem.could be speaker problem,dissconnect speakers and try to power on if still no go it is job for technician.If it works one of your speakers has a short on it,good luck
May 14, 2007 | Denon AVR-1601 Receiver
Denon AVR-2106 Receiver Logo
304 people viewed this question
Top Denon Audio & Video Receivers Experts
Level 1 Expert
Tech Leprechaun
Tech Leprechaun
Are you a Denon Audio and Video Receiver Expert? Answer questions, earn points and help others
