Question about Samsung HP-R4262 42 in. Plasma Television
How to put in new bulb - Samsung HP-R4262 42 in. Plasma Television
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
There is no bulb in this plasma TV, the front panel is one whole piece , thats the screen itself.
You may need a board or two replaced ,
I would suggest calling a repairman these are not easy to fix, you could do more harm than good.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Roety
Posted on Sep 30, 2009
Primer bulb not pumping fuel,new bulb !
are you sure you put it on the proper direction . they only work one way normally
Feb 16, 2017 | Garden
How do you put a new headlight bulb in a mazda bongo 2008?
The bulb holder is at the back of the lamp, press in and turn anti clock wise , the holder will come out with the bulb, pull the bulb out.
Oct 14, 2014 | Pyle 100/80 Watts Halogen Headlight Bulbs...
Wired in new directional on sportster wont flash
From your description, it sounds like the new bulbs (that won't flash) are LED bulbs.
When you replace the stock Harley incandescent bulbs with LEDs, you NEED to add a LOAD EQUALIZER to make the bulbs flash:
http://www.jpcycles.com/product/381-877
The amp draw is different with LEDs, and they won't flash without the equalizer.
May 06, 2014 | 2001 Harley Davidson XLH Sportster 883...
Change license plate lamp bulb 2004 Mitsubishi endeavor
there SHOULD BE AT LEAST TWO SCREWS HOLDING THE LICENCE PLATE LENS IN PLACE .REMOVE THE SCREWS AND PULLTHE BULBS OUT,THEN PUT (NEW BULBS)IN PUT IT BACK TOGETHER,MAKE SURE THE NEW BULBS WORK BEFORE PUTTING IT BACK TOGETHER
Feb 26, 2014 | 2004 Mitsubishi Endeavor
1999 ford escort wagon my brake light fuse blows everytime i put one in
remove your tail light bulbs than put in a new fuse if it does not blow it is a bulb socket put one bulb back in check the fuse if it blows remove bulb. than put bulb in other socket if it doesnt blow with new fuse you will know what socket to replace. if this was helpful please leave feedback
Apr 12, 2013 | 1994 Ford Escort
Lights and fan not working on my microwave
was the fan working before you replaced the bulbs? Did you check the old bulbs ie filaments broken....if two bulbs stopped working at the same time probability suggests that the problem was not the bulbs, especially since the breaker fired when you put in new bulbs.
Could be a short inside ...if you are not brave enough to take it apart and inspect better you take to be looked at ...better a fried microwave than a fried you...
May 29, 2012 | Microwave Ovens
Put a new projection bulb in.. whats the green
it is very possible you did take out the bulb housing and make sure you installed the new bulb correctly inside the housing and double check the way you slide in the bulb housing slowly making sure you do not force it in then make sure you reinstall bulb cover properly also!
techman
May 09, 2010 | Televison & Video
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
Lamp went out, ordered new bulb and put in but TV did not come back on but the bulb light keeps flashing light orange. Sent new bulb back just in case it was faulty & ordered another 1. I just received...
Make sure lamp cover is put back in its position properly after bulb replacement.
If I have info about model and brand of your TV then I might offer better help to fix it.
Jan 15, 2010 | Televison & Video
Need to replace primer bulb on a briggs & stratton lawn mower
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
Apr 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Samsung HP-R4262 42 in. Plasma Television Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
