Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Makes clicking noise every two minutes. freezer is thawing and top is not cooling
  • 4,070 Answers
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Sep 30, 2009
How do you add a switch to disable the thaw cycle from an Amana top freezer fridge.I need to do so i can use solar power on my fridge.the thaw unit uses to much energy so when i am boondocking i can switch...
while i do not reccomend doing this since more energy is used in running the components to make is cool (compressor,compressor fan & freezer fan) all 3 must run to keep it cool while the defrost comes on for 25 minutes about once every 4 days as compered to the cooling components running a average of 24 hrs during the same time span as compared to 25 minutes is to disconnect teh wires from the defrost heater behind the freezer back wall
ps if you read this and give me a bad rating i do not care
Aug 11, 2011 | Amana ATB1832AR Top Freezer Refrigerator
We had a new oven put in 2 days ago, and the installer turned off the circuit breakers. Ever since he turned it back on my side by side has been making a clicking noise (like a relay). Then it will hum...
Remove the bottom front panel of the fridge and locate the defrost timer. This is a small circular motor with a screw slot in the center. Turn the slot CLOCKWISE ONLY and listen for a click. As soon as you hear the click stop, wait about five minutes and feel the walls of the freezer they should now be cold.If this happens again the timer will need to be replaced. Thank you, Dana
Oct 18, 2009 | Refrigerators
Freezer is thawing - water dripping -
Hi, if the clicking noise is coming from the back, it is the relay on the compressor. It os possible that the compressor is bad but, most common it is the relay.
Is this under 5 years old? (warranty)
Please let me know if I can assist you further.
Vic
May 30, 2009 | Maytag MTB1504A Top Freezer Refrigerator
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Whirlpool Side by Side not cooling, not making ice,
your start system is out on the compresser you wil need to replace it you can get a factory oring. or uy a gernic kit like a Supco Pro-41 it will fit all ref. at half the price
May 10, 2008 | Refrigerators
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
275 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
