Computers & Internet Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant log on to the internet on my other computer it tells me minimal or no connection
Anonymous
Level 2:
Scholar:
  • Expert 98 Answers
  • Posted on Sep 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
98
Questions
0
Helped
39842
Points
293
Please ensure that your security settings are correct. Also make sure you have entered the correct password in your security enabled network (sounds like you are using a wireless connection). If you are behind a firewall or proxy server ensure that the internet settings are correct. If your are using IE go to tools - internet options- connections- LAN settings to setup your proxy if you are using Firefox go to tools - options - advanced - networks - settings tab to configure your proxy. The steps are almost identical for all browsers.
Cant log in keeps telling me wrong password
Not sure of much detail on what you're trying to log into but most applications have a option for forgot password or forgot screen name. Check with the website that you are dealing with to see if you can contact them to get your password reset.
Cant log in ; computewr will not run
Shut your computer down and turn it back on (not restart, turn it off) while its coming on, rapidly hit the F8 button until the black screen with the white font appears. Stop hitting F8, and select Safe Mode. The computer will start up with the minimal functions to operate. Now, run your antivirus program, what ever it may be. When it's done, shut the computer off and turn it back on, unless the computer tells you to restart. Then try to log in again.
I cant log in I let someone use my computer is this why
Hi Good Day,
1) if you cant log-in to your computer then you have to call your computer support number so that they will be able to reset the computer log-in details.
2) if you cant log-in to your email or to other application, all you have to do is to reset your password.
3) if you cant log-in to your network / internet, try check on where your computer is trying to connect.
try these steps first, if this won't work just send us a question again.
Thanks.
I cant log in to yahoomail what can be the problem?
1. Do you have Internet access?
2. Are you using the correct password and logon?
3. Have you tried logging in on another computer connected to the Internet?
3. Has your Yahoo e-mail account been closed and or suspended?
4. Try contacting Yahoo via another computer for assistance.
My PS3 is telling me that it "succeeded" in obtaining my IP adress,but now its telling me that an error occured during communication with the server
To me it sounds like you are hooking your PS3 through a computer to the internet. If so there is an easy fix for your problem. On your computer open Control Panel, and then open Network Connections. Right-Click on your internet connection and select properties, then on the top tab select Advance. This will open up your network sharing. In the box that says (Internet Connection Sharing), check the box that says (Allow other network users to connect through this computer's connection) click OK. Once you do this it will promt you with a message that some modifications made will not take place till the connection is reset. Then just log off the internet and re-log back on. Then proceed to start your PS3 and redo the internet connection settings on the PS3.
Cant sign in to yahoo
Javascript is turned off. Turn it on by going to tools > internet options and checking the box that says enable javascript.
Please rate, thanks!
1helpful
3answers
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
I cant log in, PLEASE help me.
first ..you do have your own rooter dont you?
the way you explain this problem sounds like you just logged onto which ever connection you found! did you or afamily member set up a commection using belkin54g?
back to basics!
in order to connect to the net with any device...PC (if you dont have a pc how did you send this post?)...Wii PS3 first you need to install and connect to your own internet connection device i.e.ASDL Broadband rooter..call it what you want
lol it sounds like you've been useing your next door neighbour's unsecured internet connection...nice cheap way to get connected.....but a bit of a bummer when text door go on holiday
i suggest setting up your own rooter (withyour own password)
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
