Question about Philips 15PF9925 15 in. LCD EDTV
Philips 15PF9925 TV
When turned on the screen comes on for a moment then goes black. The sound in OK. If you turn to a source with no input, the screen in ok and the menu lights up, but if you go to an input with signal the screen goes black and you cannot see the menu.
  • Anonymous Mar 26, 2014
    I turn the tv on and it comes on with a black screen and cuts off it said input locked
I had same problem, it was the backlight board. I got the part KUBNKM029A 15PF9925/17S from www.shopjimmy.com
Posted on Jul 19, 2009
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Magnavox 15mf400T/37 screen flashes on for a second then goes black
Check the game cubes video setup. You may have to enable the S-Video port on the setup menu. Also check the TV setup to select s-video for the input video source for that input.
Jan 04, 2014 | Televison & Video
When the tv comes out of standby the dtv logo appears but then the screen goes black and there is no sound
Most likely you have changed the input setting for the TV, on the remote or tv there will be a button that is "Source" or "Input" or something along these lines which allows you to switch through the various settings, one of which will be the one you are used to seeing when you turn on your tv.
Mar 01, 2011 | Televison & Video
Color image is coming out black and white
does it happen on the any input or just on tv setting?
if it's judt tv then sounds like the tuner, if it's on any input, then the video chip or a decoder on that board.
Apr 08, 2010 | Philips 26PFL5322 26 in. LCD TV/HD Combo
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 32PFL5322D/37 Black w/any of the analog inputs. Tuner ok
WHEN IT BLACKS OUT, GENTLY PUSH OR TAP ON THE SCREEN. YOU SHOULD SEE A SLIGHT WHITE DISCOLORATION WHERE YOUR PUSHING. IF THIS HAPPENS YOU PROBABLY NEED A MAIN TOTAL ASSY. DO YOU STILL HAVE AUDIO WHEN IT BLACKS OUT?
Sep 25, 2009 | Philips Televison & Video
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Philips 15PF9925 15 in. LCD EDTV Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
