Question about Lenovo 3000 J Series 2.10G Xpp PC Desktop
I recently installed a 1 G memory ram to my Lenovo 3000 desktop. It worked fine for one week, then could not start. I tried to take down the memory card and it still would start. How can I save my computer?
  • 61 Answers
If u have installed two ram's then it may be reason of probe
just reinsert the ram's but take care smaller should be inserted in 1st slot
Posted on Sep 30, 2009
I have installed 2GB of memory and my coputer freezes, when i turn it on
Try removing the old ones and it should work. The old ram would just slow you new ram down anyways.
Jun 20, 2012 | Lenovo ThinkCentre A60 PC Desktop
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
I have a Lenovo 3000 N100 laptop, and now it is not able to boot at all. Pressing power button the screen will be stuck on the first window, which displays the message "To interrupt normal startup, press...
What about removing the hard drive from the laptop and put it into sata box, to be USB external drive.
And then get out your important data, and format the hard disk.
and try again to boot???
If it doesn't work , try to replace the memory it might be the problem with the memory.
Dec 03, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Fingerprint drivers do not seem to work
besides downloading the driver, you need to install the software - it's titled usually thinkpad security solution.
Jun 16, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Lenovo 3000 J Series 2.10G Xpp PC Desktop Logo
76 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
