Question about Panasonic PT-AE3000U LCD Projector
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it recently so we know that is NOT the problem.
3 Suggested Answers
hvguy
  • 45 Answers
SOURCE: When we turn on our
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
Posted on Feb 10, 2011
I had the same problem, shortly after I changed my lamp. In my case, the fan had become very noisy too, so I suspected that it was shutting down because the fan wasn't coming up to full speed. I took the cover off and blew out the entire projector with compressed air, and this solved it for a while. Now it's happening again, so I ordered a replacement fan from PacParts. Hopefully these measures will solve the problem for you too.
Posted on Jul 26, 2012
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 17, 2014 | Panasonic PT-AE3000U LCD Projector
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI...
if you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
Apr 01, 2017 | Panasonic PT-AE3000U LCD Projector
Projector turn off into two minutes and do not turn on
If the Panasonic Logo comes and then the projectors turns off, the main board of the projector requires replacement!
Dec 27, 2012 | Panasonic PT-AE3000U LCD Projector
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it...
Feb 10, 2011 | Panasonic PT-AE3000U LCD Projector
I replaced the convergence ICs and the resistors on my Panasonic PT-53wx54j. When I powered it up, it worked great. After about an hour, the blue started to blur across the screen, and then the TV shut...
nwlounsberry,
Check all the components in the vicinitry of the convergence ICs. Concentrate on the diodes, resistors and electrolytic capacitors. In fact all the more they cost I would just replace all of them. If I had to guess I would say you have a bad electrolytic capacitor. Cost is minimal. Parts are available at http://www.mcmelectronics.com .
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 08, 2011 | Panasonic Televison & Video
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Jan 13, 2010 | Panasonic PT-AE3000U LCD Projector
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Please Help... Strange blue reflection across screen (See image)
Convergence ICs are bad and posibably th eresistors that power them. Its an easy fix if you can solder
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-AE3000U LCD Projector Logo
95 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
