Question about Maytag Neptune MDG5500AW Gas Dryer
Heat comes on but doesn't stay on - Maytag Neptune MDG5500AW Gas Dryer
  • leem5150 Sep 30, 2009
    Are they as easy to replace as the igniter? Are they both located in the same area as the igniter? I've looked for instructions with visual aids but can only find the verbal instructions which were not very specific.
  • 63 Answers
Replace the coils
Posted on Sep 30, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
How do I get this oil rad to stay on permanent? It goes off after it gets hot then doesn't come back on for a long time.
oil filled radiators have a thermostat that shuts unit off when its satisfied. just like any thermostat. I have used these heaters alot as temp overnight heat for customers with boiler/furnace problems till I could get parts in am. They always work well for me. I assume you have adjustments all the way up, what is the room temp when it shuts off and how much drop is there before it comes back on? You could have a faulty 'stat but I doubt it would be cost efficiant to replace considering the price off these heaters.
Mar 01, 2013 | Heating & Cooling
2000 pontiac bonneville blows hot and cold at the same time
Sounds like the blend door motor isn't working.
Jan 20, 2013 | 2000 Pontiac Bonneville
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Heat stays on even when temp is cool and compressor doesn't work
Have a professional diagnose the communication between the main control board, and the timer.
Aug 14, 2012 | Frigidaire FAH125P2T Air Conditioner
Heater and defroster don't work well
Connie this sounds like your thermostat in the engine is stuck open not letting the water stay in the engine block to heat up. The fix is to replace the thermostat with a new one that will allow the water to stay in the block to warm up. The typical symptoms of a stuck open thermostat is that the air will blow somewhat warm but never hot in the winter time, but it will take a few miles for the air to warm up at all. I would check with the dealership and find out what degree thermostat to replace it with. I run a 180 degree in the summer and a 195 degree thermostat in the winter just to have hot heat in the winter. I hope this helps
Nov 20, 2011 | 1992 Honda Accord
My portable AC the DPAC8KBLDB the room temp stays at 86 it doesn't go down
I assume youare part of the heat wave. 1 check the filter and while your at it clean it .. close all romms that are not in use . the air coming out of the unit shold be about 66-70 degrees . so if your not feeling any cold air you might shut down the unit for a few munites and try restarting it ..let me know
Jul 22, 2011 | Danby Heating & Cooling
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
