Question about Hoover U5258-900 WidePath Bagged Upright Vacuum
My mother's Hoover Widepath is making a funny noise. I wanted to get into the area where the brush and belt are and couldn't get access. Please help!
    Scholar:
  • 190 Answers
Please see if there are four screws, located at the corners of the brushroll opening, underneath the cleaner. Remove these screws, then remove the bottom plate.
Posted on Oct 03, 2009
Hoover Widepath Tempo - belt slips off when we start it. Can you help?
Perhaps the belt is stretched. Replace it with Hoover belt # 38528-033. Remove the rug plate on the bottom ( 4 screws ), and remove the brushroll. Place the belt around the motor shaft first, then position it around the brush, and push the brush back into the housing. Expect resistance from the belt, as it must be stretched several inches. After the brush is in place, turn it with your fingers to be sure the belt is centered, and not pinched between the brush and the housing. After replacing the bottom plate the vacuum should be ready to use.
Feb 18, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Hoover belt 38528 is broken where can we find the replacement part and how can I install it again? or is there a place to get service for this vacuum cleaner?
Try your local yellow pages and see if there's a vacuum shop around your area. If so, they will be able to help you with a replacement belt and assist you on putting it on.
Most vacuum shops carry parts for Hoover and will service the vacuum (change filters, clean brush rollers)
Mar 22, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I have a Model U57809RM Hoover Cyclonic which started making a very loud noise. Changed both belts on it but the noise persists. It seems to happen when I put the handle in the 'engage to vacuum' mode. The...
You could have a broken fan in the motor and need to replace the fan. If the noise is coming from the brush area of the vacuum, you probably have a broken bearing in your brush roller and would need to replace the brush itself.
Hope this helps.
Jan 29, 2010 | Hoover Vacuums
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Brushes do not turn
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My Hoover doesn't roll
You need to replace the belt. Part number 40201160
Oct 07, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Without having the model number, basically the bottom cover or the top cover will come off to expose the roller and belt area
Sep 30, 2009 | Vacuums
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover U5258-900 WidePath Bagged Upright Vacuum Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
