Question about Thermador 48 in Built In Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4855E / KBUDT4855E
Interior light does not always come on when door is open. after several attempts interior lights will come on
  • 358 Answers
Probably the light swicht got stock on the off position.
Posted on Sep 30, 2009
Door ajar warning will not turn off
Inside of the door will you will see a small button switch. This switch is what the computer uses to tell if there is an open door and turn on the interior lights. It should be located near the front of the door will and about half way up in the door jam. If you can see which switch is sticking they are simple to remove and replace. They will have a hex shaped bottum that resembles a bolt. Simply turn the old switch out and replace it with a new one readily available at most autopart stores and car dealerships (that have a parts department). You should never attempt to clean or oil any electrical component of a vehicle as this may chase the part to short out and pose a fire hazard. As always if you are unsure of what you are looking for (door jam light switch) please consult a professional. Happy motoring.
Mar 15, 2016 | 2001 Lincoln Continental
2007 POLO GTI 1.8T... my interior lights don't switch off? light switch turned off, engine switched off, key pulled out of ignition, door locked but the interior illumination stays on
there must be a switch on the actual light fitting to set it to 1 always on , 2 always off , 3 on when door opens , check the switch position
Nov 04, 2014 | 2007 Volkswagen GTI
Only dome light works when door opened on es300
A switch by the side of the indoor light normally is divided into several gear to feel it when the gear drive DOOR interior lights will be lit up
want know more
Mar 28, 2013 | 2003 Lexus ES 300
Where is the interior fuse for 2001 Daewoo Leganza. interior light is not working
Fuse is in fuse box under the hood to the rear of the windshield washer reservoir. It is marked EF-29 but first check to see if dome light switch is set in the center mark, ie. on/door/off. 'On' is always on, 'off' is always off, 'door' is light on when door opened. Also, bulb may be shot.
Jan 29, 2012 | 2001 Daewoo Leganza
New Never used electric range,oven door is no clossing properly,lights are always on
Unless the door is standing ajar you need to look for the manual light switch. This is normally near the other controls... allows you to light the oven interior without opening the door for food inspection via the window. If the door is standing slightly open then bring it fully down and then attempt to slip it back further into the hing slots. Oven doors normally are removable from the fully horizontal position where their springs become inactive and the stresses on the hinges are zero. This allows the hing plates to slide in or out of the slots on the oven chassis.
Dec 12, 2009 | KitchenAid KESS908SPS Electric Kitchen...
"Door Open" light and interior overhead light won't go out
Squirted WD40 on all door latches and trunk latch. Operated(opened & closed) several times and "Voila". Problem Solved. Charlie
Jun 20, 2009 | 1996 Ford Taurus
Interior lights, lights on rearview mirrow aren't shutting off.
Spray some WD40 into the latches on the side of the doors then open and close the doors several times firmly.This will unstick the door adjar switch most of the time.Start with drivers door first.
Apr 13, 2009 | 2003 Ford Expedition
Interior lights stay on after ingnition is off
Clean the contacts on the side door with course steel wool then lube them with die-electric grease, avail from most parts stores or the dealer, this should take care of the problem, if not u will have to remove the rivets and install new switch contacts both on the door and the door jam.
Feb 05, 2009 | 1995 Ford Windstar
Interior lights do not come on
Is it an old van? Can you see on the door frame a switch does it come out when the door is opened (push in and out a few times). 3 position switch on always / off always and door switch?
Apr 10, 2017 | 1999 Ford Windstar
Hi, i have cadillac sedan deville 1994 , the light sensor always read dark , so the exterior lights always on , besides when i open the door and the interior lights goes on , so the exterior lights goes...
hi
problem solved after cleaning the light sensor but the problem of twilight sentinel always exist , so if the twilight on the way of MAX the lights will remain 90 seconds ON but if i open the door and the interior lights will go on so the exterior lights will go OFF , what might be the problem?
Dec 10, 2008 | 1994 Cadillac DeVille
Thermador 48 in Built In Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4855E / KBUDT4855E Logo
129 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
