Question about Compaq Presario 1.8GHz Mobile AMD SempronT 3000+ Wireless DVD RW Notebook ( hp Refurbished Model V5005 ) (EP421UAR) PC Notebook
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp disk in the disk drive?
    Scholar:
  • 37 Answers
To replace the harddrive in computers you need to know the specifications of the Motherboard. Your laptop can handle the following:
Hard drives (include frame and connector) Spare Part Number
5400-rpm, 80-GB 407852-001
4200-rpm, 120-GB 407853-001
4200-rpm, 100-GB 407851-001
4200-rpm, 80-GB 410054-001
4200-rpm, 60-GB 407850-001
4200-rpm, 40-GB 407849-001
Go to the following site and put in the spare part numbers that i have listed and that should get you the upgrade you wanted. Enter the spare parts number above into the parts number in the search by part numbers box.
http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=9E0783B718F3439680DC3A201F33E853
You can download the service manual for your laptop at:
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
Posted on Sep 30, 2009
  • Compaq Master
  • 32,281 Answers
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Faulty toshiba mk8025gas-(pm) ineed to replace the hdd on my acer aspire1650 what drive do you recomend, do ineed sata.or ide..
A Google-search for "specifications Toshiba MK8025GAS" leads to Toshiba's "specifications" page for their disk-drive: http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/MK8025GAS
Read the page, looking for 'ATA-6' or 'SATA' or 'SATA2' disk-drive interfaces.
Feb 03, 2011 | Acer Computers & Internet
Hello I have a Compaq Presario v5000 laptop and my 80GB 2.5" IDE internal hard drive is failing. I would like to buy a new hard drive, say 200GB 2.5" IDE for my laptop will the new hard drive...
There are two types of 2.5-inch disk-drives: those with the (older) "parallel-ATA" interface, and those with the (newer) "serial-ATA" interface.
The easiest way to determine what you have is to take the laptop with you to the computer-store; they can inspect your current disk-drive, and sell you a compatible replacement.
A "good" computer-store can "clone" your existing disk-drive onto the new disk-drive,
copying all the files (your files and the Windows files), and then you can restart and resume
normal operation.
Given the "vintage" of your computer, my guess is "parallel-ATA".
Dec 16, 2010 | Computers & Internet
Not being recognized after updating drivers on MK8025GAS
Maybe your hard drive are not inserted properly in the motherboard, just check the connection. Turned Off you computer and check all connection on the hard drive then turn it on again. And try to go the CMOS or BIOS setup by pressing the Delete key on your keyboard and then try to see it the hard drive are detected by the BIOS. It it is detected your hard drive are ok but if it is not you have a problem for your hard drive and try to replace the hard drive.
May 28, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
Compaq presario v2414NR, HD acting weird.
They probably never updated the bios, and it's still looking for the old drive, if you get into the bios, you can remove that drive that it's searching for and then make sure that the new drive is being recognised at the 0 position, not 1 but zero, if that doesn't fix it we can go further but that mnmay be the problem, also go into your device manager and make sure you remove the old drive if it's still showing that it is in there. Just uninstall it and restart. the cmos settings should also be cleared by removing the plug and poping out the battery, on the motherboard, it looks like a quarter, it may stll have the old settings stoed in there Good luck, and let us know if it worked
Mar 18, 2009 | Toshiba MK8025GAS 80 GB Hard Drive
My laptop currently has a Toshiba MK8025gas hard drive, but it has been crash dumping randomly and I want to change hard drives. I also want to change to a 160GB hard drive. Is the Toshiba MK1652GSX...
The main factors in upgrading your drive are interface type and physical size, specifically the thickness of the drive. I haven't had any issues come up from substituting a drive of a different RPM yet. BTW I have a drive that's the same model as yours, it came from a computer that acted up like you're describing, the owner didn't worry about it, and one day it decided it wasn't going to wake up...you shouldn't have any trouble going from an 80gb to a 160gb drive.I believe your drive is an IDE interface, So just make sure you don't order a SATA, toshiba has comparable drives in either interface, I'd look for a good warranty period if the prices are about equal on the drives you're considering
Dec 03, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
hi rezwann,try using different jumper setting on ur hardisk it might work.
raj
May 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Driver problem
Hi Vicient,
I have the following questions to evaluate the problem.
1) What's the port your harddrive supported? Is it standart IDE cable or SATA.
I have a hardrive utility software that can detect and access any type of harddrive but you need install it at running windows.
Please email diazphi@gmail.com and dont forget to used the subject "Driver Problem" if sound interesting for you.
Sincerely,
Philip
Oct 31, 2007 | Toshiba MK8025GAS 80 GB Hard Drive
Compaq Presario 1.8GHz Mobile AMD SempronT 3000+ Wireless DVD RW Notebook ( hp Refurbished Model V5005 ) (EP421UAR) PC Notebook Logo
476 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
