Fills with water but will not agitate or spin
  • sandysantafe Sep 30, 2009
    I need to order the part and install then I will know if this works.
  • 10,515 Answers
The solution is already given by an expert named JSROCK. The solution is :-
Sounds like you have a failed motor coupling. This is an easy fix, requires inexpensive parts, but is going to take a little effort and know-how on your part. If you click on the following link, it explains step-by-step how to replace the coupling:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Brake/Clutch/Gearcase/Motor/Pump" heading. If you require further assistance, please let me know. I hope this helps you resolve your washer problem.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 30, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My maytag washing machine spins but won't agitate.
    sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
    Sep 01, 2009 | Maytag Performa PAV2200
    Fills with water and that's it!
    sounds like the timer is not advancing. Can you physically rotate the timer until the next thing (or anything different) happens?
    Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
    As washer was on final spin cycle it sounded like a belt came....
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Apr 01, 2009 | Kenmore Washing Machines
    Old model rca washer machine...will not agitate/wash the clothes,does spin.
    If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
    Sep 29, 2008 | Washing Machines
    Washing Machines Logo
    13 people viewed this question
    Top Washing Machines Experts
