Question about Whirlpool Duet GHW9150P Front Load Washer
Washer starts to agiatate,it stops shuts down and has code f24
The water comes on fine , the door locks then the moment it starts to rock n roll with the load it stops ,with the lights on the start button and the reset button/the code f 24 is on the screen and the load is stalled doing nothing,
  • 15,935 Answers
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Posted on Sep 28, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
Jul 04, 2013 | Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Code f24 comes up on mhwz2600tw00 and I changed user interface , mico computer machine control and door latch. Machine will come on with door open but when I shut door machine will not come on.
I removed back from washer and found wire broke .I also found packet with all codes and wire diagram. Repaired wire and washer works fine. I have had this washer for 2 years and the back has never been removed until this time. I think when washer was assembled wire was pinched and during all the washing in 2 years vibration finally finished breaking wire. All tech. from Maytag can't or want tell you anything about their machines. All they want to do is swap out parts and charge a arm and leg for thei service. You are wasting your time to even call Maytag for tech. support. They don't know anything about codes or anything else. If all applinces go out, refg.,dryer.washer.mico.,range, it want be replaced with another maytag.
Jan 28, 2010 | Maytag Washing Machines
F24 comes on. Just won't work. I have tried turning off power.
The F24 error code indicates a problem with the water temperature sensor. The technical explanation for this code is provided in the first image below. The location of the temperature sensor is shown in the second image. The temperature sensor is Key 24. The third image provides the testing procedure for this component. To access the temperature sensor, unplug the washer and remove the back panel. Unplug the wire harness connection to the sensor and check the resistance with a volt/ohm meter. If the sensor is apparently bad, it will need to be replaced. You can order a new temperature sensor from the Sears PartsDirect website www.searspartsdirect.com . The part number is 8181705. If the thermistor tests good, you could have a water fill problem, a wire harness connection issue or a failed control board that would cause this error code. If you need more help, resubmit your question with additional details and the full model number of your washer.
  • image53469img-th.jpgView Larger
  • image53474img-th.jpgView Larger
  • image53475img-th.jpgView Larger
  • Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Won't start
    We have a kenmore 27182 that has a very bad wabble in the spin mode. any suggestions?
    Dec 22, 2008 | Kenmore 27182
    Error code f24
    F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
    Possible causes:
    • Too cold of water or hot water is turned off
    • Temperature sensor failure or loose connection
    • Control board failure
    Dec 18, 2008 | Kenmore Washing Machines
    Whirlpool Duet GHW9150P Front Load Washer Logo
    43 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
