Question about Maytag Neptune MDG5500AW Gas Dryer
Internal gas leak of Maytag MDG5500AWW
I tested all other gas pipes, but no gas leak indication but smell... When I opened the front door, I can smell
    President:
  • Maytag Master
  • 1,922 Answers
If the flame is not a clear blue,rather an orange/blue or orange, the gas is not being completely combusted, either the burner orfice tube needs cleaning or the air to gas ratio is off and needs more air intake and this can be adjusted also
Posted on Oct 02, 2009
Gas smell in maytag dryer
You have a gas leak from the gas valve being faulty. DO NOT use the dryer until you have replaced the valve! I have been doing appliance repair for 15 years and I have seen 7 homes that have burned down due to this very same problem. Please don't use the dryer! Here is the new gas valve to order.
Keep me posted!
Nov 05, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
Aug 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer model mdg5500aww
OPEN THE DOOR AND REMOVE THE TWO SCREWS IN THE MIDDLE OF EACH HINGE. LOOK AT THE OPPOSITE SIDE OF THE OPENING AND REMOVE TWO SCREWS FROM THAT SIDE ALSO. PULL FRONT TOWARD YOU FROM THE TOP. IT IS HINGED AT THE BOTTOM. ONCE THE TOP IS FREE, LIFT THE FRONT OFF THE HINGES. THERE IS A CLIP HOLDING THE TOP TO THE CABINET AT THE FRONT CORNERS. REMOVE THE SCREWS HOLDING THE CLIPS IN PLACE AND SWING THE CLIPS TO THE LEFT AND RIGHT TO REMOVE THEM. THE TOP SHOULD SWING UP AND TO THE BACK AT THIS TIME. IT IS HINGED AT THE BACK.
Mar 24, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
286 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
