Question about Watches
How do i adjust anne klein luxury women's watch?
How do i adjust band size of anne klein luxury women's watch? band is silver plated and too large for my wrist
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
escapement
  • 2334 Answers
SOURCE: Anne Klein 10/5875 Y121E
You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
Do not forget to rate, please.
Posted on Feb 28, 2009
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
I called Anne Klein saying I wanted to purchase additional links for an Anne Klein watch I had purchased, and I was (very kindly) instructed to call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. I'll be calling tomorrow. Good luck!
Posted on Nov 04, 2009
disap1
  • 98 Answers
SOURCE: How do I remove links from an Anne Klein watch
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
Posted on Jan 10, 2010
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
I have a 3 dial AK watch. I can't seem to adjust the date and day.
You can pull out the stem on the side there is a halfway setting one click out, turn one direction for day and other direction for date, two clicks out sets time.
Aug 27, 2011 | Anne Klein AK Anne Klein Diamond watch...
Anne klein automatic watch, need to replace its time adjustment knob because it was lost... watch repair mans already checked it but cannot open the watch because its too tight..some service center i went...
Anne klein is handled by LUCERNE/CHRONOS SHOP located at Ayala malls like Trinoma in north edsa, Shangrilla in shaw boulevard EDSA, Alabang Town Center in Alabang, Muntinlupa. where is your location so that I can Give you the exact route of malls that near you. i hope i had been helped you.
Jul 31, 2011 | Anne Klein AK Brown Automatic Sport...
I purchased an ann kleine watch for my wife an the watch band is too small and i would like to have it enlarged
mcdevito75 here, Anne Klien, nice watches, Retirn to the place where you purchased the watch and ask for 2--3 extra links for the band, most Brand watches will give 1--2--3-- extra links for free when asked for, but of course there"s no guarantee of them being free. Or you can look for a small watch repair shop in your area to match up the exsisting links or a new band.
Jul 02, 2010 | Anne Klein 10 7913SVTT Watch for Women
I have an this watch: AK Anne Klein Women's 10-7127SVSV Swarovski® Crystal Accented Silver-Tone Watch I need two clasp in order for it to fit, the original clasp are lost.
Not to sound generic but you can contact Anne Klein to see if they make a replacement available.
If they do not then I suggest contacting a reputable repair house or your local jewelry repair to see if they can fix it. You really shouldn't pay more than about $20 for the clasp.
Anne Klein Watches, Attn. Service Department
29-10 Thomson Ave.
Long Island City, NY 11101
Tel. #: (718)482-4195 begin_of_the_skype_highlighting (718)482-4195
end_of_the_skype_highlighting
May 17, 2010 | Anne Klein 12 1821WMSB watch
Where can I puchase a new link for the band for my
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 15, 2010 | Anne Klein Swiss Two Tone Diamond Bezel...
How do I remove links from an Anne Klein watch band (8509 SVTT model)?
Jan 10, 2010 | Anne Klein 12 1821WMSB watch
Need extension links to wrist band of an Anne Klein Swiss two-tone watch 12/6730-1775S(6)
As a watch and jewelry repair shop, my first recommendation is to check with the maker or their customer care center. Most brands and makers usually carry a limited stock of replacement clasp/links.
If they no longer carry them, as one of the main suppliers of this product line I am usually able to supply their after market needs. Custom fitting/sizing at no extra charge and if two tone we switch out the clasp or the link with the preferred dominant color.
We offer online sales and service.
watchbandlinks com
Nov 01, 2009 | Anne Klein Two Tone Expansion Watch for...
Watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Jun 17, 2008 | Watches
Watches Logo
237 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
