Question about Refrigerators
My coils on my ge model gss22kgmc will not defrost. defrost bar just replaced. only get 22.5v when bar not pluged in when pluged in no voltage at bar,bar is new
    President:
  • Refrigerators Master
  • 1,922 Answers
Repl the defrost control board
Posted on Nov 04, 2009
I have GE refrigerator model ZIS42CMC. How do I remove the evaportor coil from the evaportor compartment so that I can access the defrost heater?
you don't as to do that will loose all the gas and you will be in a bigger cost zone than having a technician fix it
Jul 10, 2017 | GE Refrigerators
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE fridge not cold.
If the coil (in the freezer) is icing up then it's not being properly defrosted on a regular basis, ie. 2 - 3 times a day. On older models it's usually just a simple matter of replacing the defrost timer. On newer models, the defrost timer is integral with the 'motherboard', so the whole (expensive Chinese made) motherboard must be replaced because they're not serviceable.
Less likely (but possible) are the defrost heating element and/or temperature sending unit found on or near the coil itself. Least likely is a low refrigerant level, which would indicate a leak.
Mar 27, 2014 | GE Refrigerators
GE GSS25WGMC freezer ices up at top. Fan motor makes loud noise as it ices up between defrost cycles. Door gasket (screw in type) was replaced and problem a little better but not cured. I'm told...
Try replacing your defrost timer it may not be working proper also if it has the coiled heaters behind the insulation make sure they are coming on as well they do burn out.Check heaters voltage and continuity first then defrost timer. If no heated defrost its defrost timer
Apr 05, 2012 | GE Refrigerators
Gss22kgmc compressor no power
IF THE CONDENSOR FAN IS RUNNING YOU MAY HAVE A PROBLEM WITH THE MAIN BOARD.
Jan 12, 2010 | GE Refrigerators
Looking for a troubleshooting guide for ge model gss22kgmc ww. Freezer coils ice up. Suspect there is a defrost timer, or some type of sensor that monitors this function. I need a little jump start to find...
In the event this may help someone else here's a link to the technical service guide.
www.applianceaid.com/pictools/gefridge1.pdf
Reasonably priced parts can be sourced at
www.repairclinic.com
It's not hard to do most of the work with simple tools.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
