Question about GE Profile Harmony DPGT750EC Electric Dryer
Tried to take the back off, couldn't see an easy way to do that
  • GE Master
  • 8,404 Answers
My friend, you cannot work on an appliance and use the word easy in the sentence!
Pull it out, stand on your head to unplug it and remove the hose. Pull it out more so you can get back there. Best if you have a nut driver (not a screw driver). It will be 1/4, 5/16 or 3/8. You should find probably about a dozen screws to remove.
Tell me, why do you want in the back? If it is to replace the belt, remove the top and then the front. You dont need in the back.
I hope this helps.
a
Posted on Sep 30, 2009
My printer is only pulling the paper in from one side, have tried cleaning the rollers and have checked for foriegn objects in the paper feed, display reads no paper, any ideas?
My problem too, solved it easy, couldn't believe it, a pen had fallen in the paper feed slot, I didn't think it possible, couldn't see it until I took it to bits, be careful but worth a look
Sep 23, 2012 | Canon PIXMA MX310 All-In-One Printer
Cold water couldn't get into machine
Check the valve and make sure it didn't get turned off, then I suspect the water valve has gone bad. try swapping cold and hot hoses on the back of the machine and see if you get cold water when it calls for hot that tells me your water valve is either bad or plugged with sediment. Check the screens on the back of the washer where the hoses go into the washer make sure they are clean. If they are clean and still not getting water through the cold side then the selenoid valve is bad and needs replaced. An easy job you can do your self and save some money.
Here is a lionk for parts and a diagram. If this was helpful a vote with the thumbs up would be appreciated.
Thanks.
www.searspartsdirect.com/partsdirect/part-model/samsung-parts/washer-parts/Model-WF220
Jul 22, 2011 | Samsung Washing Machines
No POWER UP NO DISPLAY AFTER A STORM
you must have had a power spike during the storm, I tried to locate this model specs but couldn't,, if you can get into the back where the plug wire leads into the unit,, if there is no visible fuse, you want to look at the circuit board where the plug wire attaches to it, near that point there will be a diode thats blown, it will be easy to locate it should have pretty much exploded. if your knowledgeable with soldering you can purchase another directional diode and replace the burned one, if not, have a shop do it,,
Jun 02, 2011 | Thomson RCA 5 CD/MP3 Bookshelf Stereo...
I have a Dell Vostro 3300. It has a sim card slot under its battery. I couldn't get it working. Which software should I use to configure it? I couldn't succeed with Dell Mobile Broadband Manager...
Are you sure you have a wireless broadband mini card installed? This sits under they keyboard. I suspect you have not. The Dell site describes how to take off your keyboard (very easy - stick a thin screwdriver down behind the F12 key and gently lever upwards)
For better description, look up repair manual on the Dell site for the 3300.
If you DO have a mini card installed, perhaps it is not enabled in your BIOS?. On startup press F12 and navigate from there.
Jun 01, 2011 | Dell VOSTRO 3300 I3350M 226G 2GB 250GB...
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
Frigidaire model ES510L will not go above 288 degrees on the main oven in baking mode, any ideas?
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to Celsius instead of Farenheit (had to change it back to Farenheit).
Saved them a ton of money... cause this could have been an easy cash grab to some crook out there.
Dec 19, 2010 | Frigidaire PLES389D Electric Kitchen Range
I couldn´t run and schtask command send the
Did you tried to login as administrator account or do you have admin rights on the machine you are trying to schedule tasks.
Aug 12, 2009 | Citrix Computers & Internet
Stuck at 288 degrees
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
GE Profile Harmony DPGT750EC Electric Dryer Logo
74 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
