Question about Microsoft Windows XP Professional for PC
Forgotten administrator password of windows XP professional , my dissability has caused me allot of pain. I'm a handicap MOM OF 2 born w/out limbs, anyways i was given allot of medications for depression and antianxsiety issues plus pain, so im starting to get forget ful more. I'.m so sorry. I can't get into my normal accnt, but thought if i could get in my admin. and go in control panal and change it., is there anything anyone can recommend? plllleeesse? Thank you? Beverly mcminn
    Sniper:
  • 51 Answers
Have you ever encoutered loosing your password in your own computer?
Then asking some computer experts just to reset your password would cost you alot of money.
Well, how this steps would help you to resolve that issue.
Make sure that you follow the steps listed, and you'll be logged on asap.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Hope these steps would help you.
If you would have any questions, feel free to post it. I'll try to answer it asap.
Have a great day.
Posted on Oct 01, 2009
    Guru:
  • 204 Answers
Forgot windows xp administrator password?Using this windows password recovery tool can easily bypass windows xp administrator password ,just with a few steps.And it can be burnt into a reset disk.
Posted on Mar 05, 2010
    Guru:
  • 243 Answers
If you lost windows password. I think the best solution is making a windows password recovery disk with the third part utility. The disk can work perfectly to recover windows password to “Blank”. It is also useful for administrator password recovery, you can wrote it to an blank CD or USB flash drive to recover administrator password. Booting up and clearing a password takes a minute or two works like a charm.
more info: http://www.windowsloginrecovery.com
Posted on Mar 01, 2010
    Guru:
  • 108 Answers
Using the Third part utility---Windows Password Unlocker is highly recommended
1.Download Windows Password Unlocker from Password Unlocker Official site http://www.passwordunlocker.com/products/wpu.html .
2.Decompress the Windows password unlocker and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Password Unlocker.
3.Insert the newly created CD into the locked computer and re-boot it from the CD drive.
4.After launched the CD, a window pop up with all your account names(if you have several accounts); select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
Posted on Oct 15, 2009
  • 103 Answers
Do the following
Start-> Run.
Hit cmd and press enter.
net user Administrator * and hit enter
now it will ask for a new password
type the new password. You wont have anything appearing on the command window when you type. Just type the password and hit enter. Reenter Password and confirm it.
Posted on Sep 30, 2009
I forgot my windows 7 adminstrator password
Windows Password Unlocker can help you reset forgotten Windows local administrator, domain administrator and other user account passwords on Windows 8/7/Vista/XP/2008/ 2003/2000.
Jan 18, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
Tip
Three Tips for Windows XP Administrator Password Recovery
Unlike Windows 7 and Vista, the default administrator account on Windows XP is enabled and not password protected. And by this unique feature, you can easily reset a forgotten login password to Windows XP when you are locked out of computer. But if you added a password to this built-in administrator account before and now cannot remember its password, what will you do to reset this forgotten Windows XP default administrator password? Here's some advice on <a href="http://www.anypasswordrecovery.com/windows-xp-administrator-password-recovery.html">Windows XP administrator password</a> recovery for you if your Windows XP machine is in use.<br /><br />Tip 1: Take advantage of password recovery disk<br /><br />Provided a password reset disk for the default administrator account is created in advance, Windows XP administrator password recovery can be completed within a few clicks.<br /><br /><img src="yaoch_1.png" /><br /><br />Step 1. Go to Windows XP logon screen and enter a wrong password for the administrator account.<br /><br />Step 2. Press Enter to pop up the "logon failed" dialog box, and click "use your password reset disk".<br /><br />Step 3. On the Password Reset Wizard screen, click Next to change this administrator password.<br /><br />Tip 2: Try Windows Password Recovery Software<br /><br />If you forgot Windows administrator password without a password reset disk, don't feel impressed. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> can solve your problem. It allows you to create a password reset CD/DVD to reset lost Windows XP administrator password.<br /><br /><img src="yaoch_2.png" /><br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable password reset CD/DVD.<br /><br />Step 3. Boot your locked computer form the CD/DVD.<br /><br />Step 4. <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html">Reset Windows XP password</a> under Win PE.<br /><br />Step 5. Log on computer via this administrator account without password.<br /><br />Note: With intuitive GUI, you can defeat Windows XP administrator password within a few clicks, regardless of your level of computer knowledge. 100% recovery rate guaranteed.<br /><br />Tip 3: Use a user account with administrator permission<br /><br />It is well-known that users can create 2 kinds of administrator account on Window XP. One is a user account with administrator privileges while the other is the built-in administrator account. So when you forgot Windows XP default administrator password, you can log on computer with another kind of administrator account and then do as follows:<br /><br /><img src="yaoch_3.png" /><br /><br />Step 1. Right-click My Computer icon to select Mange.<br /><br />Step 2. On the coming up classic computer management window, expand Local Users and Groups folder, and then expand Users folder to display all user accounts on this computer.<br /><br />Step 3. Right-click Administrator and select Set Password option.<br /><br />Among these tips, it's highly suggested you try tip 2 that changing Windows XP password with Windows password recovery software as it is can be applied to every lost Windows password circumstances. And it is simple and fast.
on Apr 22, 2011 | Computers & Internet
Tip
How to reset a lost or unknown Windows 7 password to blank?
Now Windows 7 has been official released for more than 1 year. With its increasing sale, more and more people may get confused by a forgotten or lost Windows 7 password. Well, if you forgot Windows 7 password, you can simply get help from Windows password recovery software for <b><a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password reset</a></b> or recovery.<br /><br /> What can Windows Password Breaker do for you?<br /> <br />Windows Password Breaker is professionally designed for common users to reset forgotten or lost Windows 7 password. It has 3 editions to meet your needs.<br /> <br />Standard Edition - Help you burn a bootable CD/DVD to reset forgotten Windows local password (administrator and other user passwords). Windows 7, Vista, XP, and 2000 are supported. <br /> <br />Professional Edition - Help you burn a bootable CD/DVD or USB flash drive to reset forgotten Windows local password (administrator and other user passwords) . Windows 7, Vista, XP, 2000, 2008(R2), 2003(R2) are supported. <br /> <br />Enterprise Edition - Help you burn a bootable CD/DVD or USB flash drive to reset forgotten Windows local password and domain administrator password. Windows 7, Vista, XP, 2000, 2008(R2), 2003(R2) are supported. <br /> <br />Why to use Windows Password Breaker?<br /> <br />Here are just a few features that make Windows Password Breaker stand out, as well as the reasons why you choose it if you lost Windows 7 password.<br /> <br />Powerful. You won't ever need to go searching for any other tools - you can use this Windows password recovery tool when you lost or <b><a href="http://www.recoverwindowspassword.com/">forgot Windows password</a></b>, to reset various Windows passwords, like Windows local password (including Windows administrator, standard and guest password) and Windows domain administrator password.<br /> <br />Easy and fast. No computer reinstallation, no old password, no computer skills. This Windows password recovery software personally assists and guides you in safely regaining access to your locked computer in less than 5 minutes when you <b><a href="http://www.recoverwindowspassword.com/windows-7-forgot-password.htm">forgot Windows 7 password</a></b>.<br /> <br />Reliable. Windows Password Breaker is widely used by lost Windows password users. It has little bad impact on your computer during Windows password recovery. All your computer data all well kept after lost Windows password recovered. No data loss or data damage. <br /> <br />Works all popular Windows OS. This Windows password reset software runs equally well for users with Win PCs, like Windows 7/Vista/XP/2008(R2)/2003(R2)/2000. So if you forgot Windows Vista or other Windows OS password, you can still use this Windows password recovery tool. A single code of it can be used for up to 3 computers of your own.<br /> <br />How to use Windows Password Breaker?<br /> <br />1. Download Windows Password Breaker.<br /> <br />2. Run the program to burn a password reset bootable CD/DVD or USB <br />flash drive.<br /> <br />3. Reset lost Windows log on password to blank.<br /> <br />4. Log on again with no password.<br /> <br />With just 4 steps to reset a <b><a href="http://www.recoverwindowspassword.com/lost-windows-7-password.htm">lost Windows 7 password</a></b> to blank, you can get the software when you are locked out of your computer.<br />
on Jan 12, 2011 | Computers & Internet
I forgot Windows XP Administrator Password. Help!! How can I gain access to a computer if I forgot the administrator password? How can I reset the administrator password if I forgot it?
This is an easy way to reset your forgotten administrator password:
Step 1: Download and install Windows Password Breaker.
Step 2: Burn a password reset CD/USB with the program.
Step 3: Remove the password with the created CD/USB.
You need to prepare a CD or USB.
Sep 02, 2011 | Microsoft Windows XP Professional
I forgot my Pc security password and how i get the password?
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
Jan 23, 2011 | Microsoft Windows XP Professional With...
Forgot my administrator password
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker
  • In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users.
Oct 27, 2010 | HP Elitebook 8530p Notebook
No password
I don't if it work for you or not!
but it is the easiest thing to do now!
Step 1: Start Windows PC
Step 2: When you can see the Windows login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box
Step 3: Type Administrator as Username and leave the Password field blank
Step 4: Press the Enter Key and then you can be able to login the default windows administrator account which is it created by default when install windows.
Note: When you input the key combination Please don’t put the cursor on any account. And if you change the name or password before, you cannot login by this way.
May 08, 2010 | Microsoft Windows XP Professional for PC
Forgot password and unable to do anything now
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Apr 17, 2009 | Computers & Internet
Forgot my administrator passwords
Hey, Offline Nt Password can reset any users on your PC.
Use this utility to reset forgotten Win XP/Windows Server/Vista Administrator Password (or any other account).
Unzip, Burn to CD, Boot from this CD and follow on screen instructions.
DOWNLOAD:
http://home.eunet.no/~pnordahl/ntpasswd/cd080802.zip
Jan 08, 2009 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
351 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
