Question about Amana Refrigerators
I have amana AFD2535DEB and the handle to the bottom comes loose
I have amana AFD2535DEB and the handle to the bottom freezer drawer will come off if sometimes pull hard, how can that be fixed? or can it. when i put it back on i notice ths the things that it slides on are loose. would it help to tighten them?
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Posted on Feb 13, 2009
ldaala
  • 65 Answers
SOURCE: Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
Posted on May 26, 2009
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
  • 864 Answers
SOURCE: How do I tighten the refridgerator door handle on a AFD2535 french door refrigerator
Instructions for removing and installing door handles are on pages 5-6 of manual at:
http://shop.amana.com/assets/pdfs/literature/User%20Instructions%20-%20W10175445A.pdf
Posted on Jun 03, 2009
I have an amana afd2535deb the freezer stays cold but the fridge is warm and i feel no flow from the fridge bottom vents
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Refrigerators
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerators Logo
107 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
