Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I had a power surge and ever since my ice maker won't fill with water. If I manually pour water in the ice maker, it will dump the ice.
  • 3 more comments
  • jcturpen Sep 30, 2009
    Does this apply to a Whirlpool Frig? I indicated the wrong frig when I posted my problem. The Fridge is a Whirlpool 25.6 side by side.
    Thank you. I was wondering where the "water pump" is located.
    Thank you!
  • Mike Smith
    Mike Smith May 11, 2010
    But , yes . He is correct on his solution .
  • Mike Smith
    The " water pump " red is refering to , is the dual water inlet valve behind the refrg , what the wall water line connects to on the refrig .
  • 34 Answers
The water pump is burned out.
the power surge most definitely caused this.
locate the water pump and with a multi meter test for power.Replace.
Posted on Sep 30, 2009
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung RS277 ice maker not filling with water but have water through dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 21, 2009 | Samsung Refrigerators
Ice maker won't dump ice...seems to fill
Aug 17, 2009 | Refrigerators
Ice maker will not fill with water
Aug 16, 2009 | Refrigerators
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Aug 15, 2009 | Refrigerators
check and make sure there is no water or ice in the ice-maker mold ,if not pour 5 oz. of water into it , if the ice-maker dumps the ice out in under 2 hours then you have a problem with your water valve , you can also check and make sure the inlet fill tube entering the the mold isn't iced up
May 08, 2009 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
107 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
