Question about Acer Aspire 5520-5908 Notebook
Hello! I have an Acer Aspire 5520G Laptop 2 years old. On the weekend it suddenly decided to stop working. When I push the on button it goes to power up, the light flashes green and then it clicks and stops. A few seconds later it will go to power up again and then it clicks and stops.The whole process will keep reapeating itself.The only way to stop it is to remove the battery and make sure the mains power is disconnected. The screen stays black and doesnt boot up at all. Any advice apart from throwing the laptop out the window? It cost a fortune and has been nothing but trouble! Here I am on the web using our 8 year old slow but faithful desktop computer!
  • our4ballerin Nov 08, 2009
    HI there
    Sorry I had to have my Laptop repaired by Acer. It turned out to be that the mainboard was faulty. I was out of warranty but under NZ Consumer Act I was able to have it fixed at no charge to me.
  • 700 Answers
Try to check the memory card reseat or clean it ( the edge connector with gel eraser), do this when battery is out and its AC power plug.
Did it undergoes some maintenance check in two years. Maybe you should, dirt, dust build up maybe the cause, and some contact is building a thin film of insulation commonly on copper coated connector.
Sometimes some add in device is out/faulty causing erratic behavior. Other thing is the hard drive and ODD devices. Reseat ODD and hard drive.
And oh, check your battery, one usual suspect of that.
Posted on Sep 30, 2009
These laptops are legendary known about these errors. Rumor says it is caused by loose CMOS batteries. Try to push the case of the laptop in the middle of the keyboard when turning on with medium force. It is even better to push where the CMOS battery is installed. Just Google for some motherboard pictures to find its location (its perhaps somewhat left or right next to the power on switch).
If this solves the problem you should find a way to permanently prevent your CMOS battery from getting loose.
Posted on Apr 02, 2010
I have thesame problem with my acer 5520g, when i press power buttonthe fan will be on for 5 seconds only and the light will start to blink every foe second, i canot turn it off only by removing the powed cord and battery, i was able to make myu laptop run for 1 month by twisting my laptop, holding one hand in the other side twisting opposite to each other but its only work for one month and its suddenly go back to the same probnlem, i tried to puss down in the middle ( keyboard) a little bit hard and it only working for 1 week only, third times i disassemble all the pieces, only the motherboard, cou, video card and ram remaining and i tried to push any part posibnle and it work for 1 minute, i have brand new batery and it fully charged, i charged it from my frend laptop (samebrand and model). now what ever i do i canot make my laptop run for even a minute, my opinion are, there some parts is loosing, cmos bar\try was ok, i test it with a tester or some spot need to be re spot by solder, but i think procesor and video card is ok because i made it run 3 times, mainly is the motherboard, its a loose connection, it has no waranty anymore, two of my friend with thesame laptop and brand and model was also now a victim of these thesame priblem and too many of us are now suffering with these kind of problem with these acer brand specialy 5520g model...
Posted on May 06, 2010
    Problem Solver:
  • 5 Answers
Same laptop Same problem. Did anyone ever ger an answer about how exactly you managed to get the laptop fixed without any charge? Which article from the NZ Consumer Act helped you? Getting desperate
Posted on Mar 22, 2010
Hi! i have the same problem with my laptop(5520G) and the warranty expired. Can you please tell me how exactly did you manage to get the laptop fixed without any charge? Which article from the NZ Consumer Act helped you?
Thanks, Cristi
Posted on Nov 20, 2009
Well, i have exactlly the same problem on my acer aspire 5520G and i wondering i you manage to solve your problem. Thanks
Posted on Nov 08, 2009
I have a portable computer ACER ASPIRE 5520G. When i power on the computer by pressing the power button the power button light on and off but the compter does not power on.
try remove power supply and battery and long press power button to 60 sec. then plug your power supply without battery then press power on!
Feb 04, 2013 | Acer Aspire 5520-5908 Notebook
Hello. I have an Acer Aspire One netbook, about 2 years old. While I was reading a pdf document the screen suddenly flashed a message saying "going to hibernate now" or something similar, and the...
Unplug the netbook from the AC adapter and remove the battery. Replace the battery, charger, and power the netbook back on. This is called a hard reset.
Apr 13, 2011 | Acer Aspire One PC Notebook
My aspire 5520g/5220 laptop just stopped coming on
first check your laptop charger if it ok than check motherboard power supply of laptop..there are must some problem on motherboard.
Apr 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
White Screen Problem while starting Acer Aspire 2710z laptop
Unfortunately it sounds like bad memory. Depending on your memory configuration you can try swithing out memory sticks. Check with your manufacture about memory configuation requirment before trying this. If you're unsure how to do this it's best to take it to someone who does know how.
Mar 25, 2010 | Computers & Internet
Acer Aspire 5520g continuous restart on off problem
try cleaning the air vents with a hoover. worked for me mine kept overheating and shutting down it was down to dust
Mar 16, 2010 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520g black screen, power light blinking
go to acer website ...go to dowloads section..select ur model ..n download latest bios
Nov 06, 2009 | Acer Aspire 5520-5908 Notebook
Problems after formating acer aspire 5520G
put windows 7 on it it works better than vista it are now for free dowload the release version from microsoft and works til juni next year for free
Sep 27, 2009 | Acer Aspire 5520-5156 Laptop
I cannot turn on my acer aspire 5520. when i press the on button, the light flashes and goes off. plzzz help
Hi there! this is a possible power supply problem or the power button from the laptop is faulty.. But first I suggest that you use a different working power adapter that is same power supply for your laptop and try to remove the battery and try to clean the contact point of your batter, to further isolate the problem, if you did this troubleshooting and still doing the same thing I suggest that you bring ur laptop to acer for check up and repair of the power supply system of the laptop, if your laptop still under warranty, bring it to the service center right away.. if not then u can try doing the troubleshooting..
Aug 12, 2009 | Acer Aspire 5520-5908 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Problem with battery or motherrboard?
ok..first thing..does it run ok with no battery on mains power?
Feb 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5520-5908 Notebook Logo
975 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
