Question about Goodman Heating & Cooling
I have a GMP 100 furnance, The induction moter does not come on and I have three (3) blinks coming from the red light. whats the problem
  • 24 Answers
Remove two wires to inducer, make a call for heat at your stat , if there is no120 vlts to inducer you havea bad controlboard, if you have 120 your motor is bad, the inducer is powered before anything
Posted on Sep 30, 2009
3 lights blinking upon starting Epson L200
if the three lites, two red (1 paper jam and second ink tank) ligts and one green light is on. than what is problem in printer please how can solve this problem easily.
Jun 13, 2012 | Epson Office Equipment & Supplies
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a Goodman gas furnance. The furmance kicks on the glow rod lights and then the furnance shuts down after about 60 seconds it goes through the same cycle. The burners never come on. What's wrong?
Gas valve is not kicking in or gas shut offs are off. Can you check voltage where 2 wires connect to gas valve. Can you see blinking lights thru lower door window and count blinks. Code sticker should be on inside of lower door.
Jan 23, 2011 | Heating & Cooling
My gmp series heater comes on for 30 seconds to purge exhaust and goes off for 2 seconds and starts over red light flashes constantly gas valve never opens igniter doesnt heat up
Sounds to me like your pressure switch is bad or the hose has a hole in it. If the pressure switch does not close, the unit will start. It will try again until it goes into lock out. normaly three times.
Oct 13, 2009 | Goodman Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Goodman Furnace GMP 050-03
You need to check for 24 volts across the gas valve as the ignitor glows. If you get it, it is a bad gas valve. If there is no voltage or strange voltage, replace the control board.
Dec 09, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
150 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
