Question about Imperial IR-6-C Elite Gas Kitchen Range
Need to light pilot light of griddle on imperial stove
4 Suggested Answers
  • 193 Answers
SOURCE: How do you light the
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Posted on Sep 23, 2010
  • 205 Answers
SOURCE: I have an old Vulcan
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Posted on Sep 24, 2010
SOURCE: where is the pilot light for imperial range oven
Stick the torch or whatever way back on the LEFT hole. You will see the pilot go on. Do not let go of the red button (which you are holding the whole time) for 60 seconds after it's lit.
Posted on Aug 18, 2011
I have 36 in Imperial SS gas stove with constant pilot lights on .i believe its a commercial unit.I am unable to start pilot light for oven ,rather it starts and as soon as i release red button ,flame goes...
it sounds like the thermocouple which is heated by the flame is faulty its purpose is to hold the gas valve open so gas can flow but if the pilot goes out the thermocouple stops producing electricity and so the valve closes its there for safety reasons
Oct 13, 2014 | Kitchen Ranges
Miraclean pilot lighting
I'm not familiar with your particular appliance but all gas fired appliances have a thermocouple and igniter.
the thermocouple is designed to allow/prevent the gas valve from opening.
They commonly go bad on stoves and hot water heaters.
should you wish to attempt a repair yourself l
look on the Internet for a picture of the thermocouple for your unit , turn the gas valve off, then attempt to clean the thermocouple first with some medium grit sandpaper. Just some gentle rubbing a few times can take carbon buildup off.
Then try the start proceedure again. If the pilot light or burners do not light the the thermocouple is the least expensive component I can think of to repla e. usually less than $20 and very intuitive to do.
if that does not work depending on your ability you may either need to replace the igniter or gas valve. Or. Call a pro.
Be safe and keep the gas valve on the unit off until you are ready to restart each time
Hope this helps
May 18, 2014 | Keating Miraclean Griddle, Drop-In, Gas,...
Where is the pilot light
location of pilots on oven griddle and stove top
Dec 17, 2012 | Vulcan G36L Gas Range
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
How do you light the pilot for the flat top section of our Imperial 6 top stove?
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
Light pilot for oven
IF IT HAS A STANDING PIOLOT YOU SHOULD CHECK YOUR BOOK ON HOW TO LIGHT.IF YOU DONT HAVE A BOOK SOME IF THE IMPERIAL STOVES YOU HAVE TO HOLD IN THE TEMPERATURE KNOB IN THEN LIGHT IT. HOLD THE KNOB IN FOR A MINEUTE THEN IT SHOULD STAY ON.REMEMBER GAS IS DANGEROUSE,IF YOU SMELL IT YOU SHOULD STOP AND LET IT AIR OUT.GOOD LUCK BE SAFE
ERIC
Jan 21, 2010 | Imperial Ovens
I have a vulcan60CL77R stove and the oven pilots keep going out. Also I need 6" pilot tubes for front burners. Can you help?
Yes we can help you. We service Vulcan and we love these units. May I begin to telling you that you have a great range?!! This is either your ignitors or the gas valves, but most probably the ignitors out if the pilots keep going out. I will check on the price and availability of all the parts that you need and respond to this request. Could you please send me your email address? We look forward to working with you on this issue.
Sep 29, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Pilot wont light.
Firstly make sure the gas knob is exactly in the pilot mode some are finiky and won't light unless in exactly the right postion. Make sure once lit when pushing down on the pilot knob that you hold it down long enough for the thermocouple to sense the pilot. Barring both of those the most likley culprit is the thermocouple itself is faulty and can easily be removed usally with a couple of screws and a small adjustable wrench.
Dec 29, 2007 | Imperial IFS40 Deep Fryer
Imperial IR-6-C Elite Gas Kitchen Range Logo
1,302 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
starztruck4u
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
