Question about Sharp AQUOS Blu-ray Disc Player
Sharp BD HP21 Won't recognize USB drives
I'm trying to update the firmware on the Sharp BD HP21U bluray player but it won't recognize any of the USB drives I've tried.
I've tried two different drives, have erased and reformatted both of them to ensure they are clean and FAT32 but the set up program on the bluray player still refuses to recognize the drives.
Actually, when I first plug a drive in the player says "Drive not formatted" and suggests using the set up utility to format it. - when I try to do that in the USB Memory Management section it says "NO USB MEMORY"
What is going on and how do I fix it? Can I burn a CD with the firmware update? Can I get the player to recognize the USB drives ... or should I just take this thing back to the store and tell them to shove it?
You have to make sure the files, you downloaded to your USB stick, are not in folders. Mine worked after this. I am still having problems with pixelation on newish discs. I read somewhere that if I plugged a USB thumb drive into the Sharp HP21 it will aid the processing and work better. Does anyone know if this is true as I often get poor picture quality on what looks clean LoveFilm BR discs. (No problems with standard DVDs.)
Posted on Oct 06, 2009
I am seeking software update for my BD-HP210U Blu-Ray Player.
You should have an option in the menu which says Update Firmware, failing that the Sharp website will have the update which can be burnt to disc and inserted into your player.
May 30, 2010 | Sharp BD-HP21U Blu-Ray Player
Tip
Bluray Firmware and where to get the latest downloads
bluray player firmware
Here are a list of bluray players and the link to help you get the latest firmwares. I will be adding several players and for some you may need to click on the manufactures link as not all have a direct link for every player.
AMEX
BD-P1-None out but you can see the home page for Amex here
Blucobra
EZ3000-no firmware and it seems the homepage is gone.
BUSH
BD-0-no firmware. Player was sold in England and has been discountinued
Curtis Mathes
CMMBX130
cmmbx72
Daewoo
DBP-1000-None available
Daewoo-2000-none available
Denon
DBP-2010CI
DBP-1610
DVD-3800BDCI
S-5BD
DBP-4010UDCI
Funai
NB500MGXA
NB500MG1F
Insignia
BRDVD
2BRDVD
BRDVD3
BDLIVE01
BRDVD3CA
BRHTIB
NS-WBRDVD
SAMSUNG
HT-BD1250T
HT-BD72000
BD-P1500
BD-P1590
SHARP
BD-HP20
BD-HP21
BD-HP50
I will be updating this all the time and list when it was updated. Please check back and send me a message in the comments section if you have anything to add. Thanks for your help!!!
ver 0.3.2 posted on 7/08/2010-Added several more players and updated links.
on May 18, 2010 | Audio Players & Recorders
BD-HP21 cannot find update on my flash drive. Formatted the flash drive twice (FAT32 & NTFS) extracted the zip file on to the hard drive and copied the update file to the flash drive. Help!
Let's start from the beginning again. Go ahead and reformat your usb device to fat 32 wiping everything. Next go to www.sharp.ca
Click on Service Support on the left and next click on downloads. Select Bluray, next and then your model number, done.
Then save the firmware directly to your usb device.
If the usb device is larger than 4GB it might not work.
If the download still does not work try formatting the usb device again this time to fat and then dowloading again.
You may need to reset the bluray player. Hold down the power button on the front of the unit until it says reset. Then put the usb device into the player before turning it back on. Press setup-->settings--->software update.
May 05, 2010 | Sharp BD-HP21U Blu-Ray Player
My blu ray player won't play blu ray copy of avatar
Try completing the update.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
May 04, 2010 | Sharp AQUOS Blu-ray Disc Player
Bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Apr 26, 2010 | Sharp BD-HP21U Blu-Ray Player
My aquos bluray player has stopped playing my blu rays it reads the disc then says reading complete but then theres only a black screen.it plays some older dvds but i bought survival of the dead today and...
Sound like the firmware needs to be updated for the newer encryption schemes had the same problem with my bd-hp21u with a couple of new bd discs. You will need a 1gb or smaller USB drive to put the updated firmware on which Sharp doesen't tell you. The rest is in the manual or available from sharp support.
Mar 15, 2010 | Sharp AQUOS Blu-ray Disc Player
I have a aquos bluray modle # HP21U 810803152
Hello, we had the same problem with District 9. If your in uk you need to go to http://www.sharpelectronics.info/Software.aspx, select the sharp bd player make e.d. BDHP21H and select download to your desktop. If you not in uk go to the sharp web site relevant to your country. Once download is complete you need to extract files (they are zipped). In our case there were three files downloded, one being directions, the 2nd the actual software update and the 3rd something th do with version numbers. Once unzipped copy and paste the file ending in .RVP only to your usb/pen drive. Now insert the usb/pen drive into the bd player and follow the set up instructions. IN the case of our bd player (which is a different make to yours) we selected set up, software update and then just followed the directions from there. But probably best you follow the instructions given by sharp on thedownload. Best of luck.
Dec 26, 2009 | Sharp AQUOS Blu-ray Disc Player
I hate blurays, pain to update onto usb plug
Okay you need to visit the sharp website download the update onto a usb flash drive and then plug it into the unit this will update the firmware inside if you have any questions further call sharp on specifics of the firmware update. You will find that you whille have to do this every so often as blue ray disk are being compermised rapidly in order to provent piracy that function needed to be intact. Thanks for visiting fixya.com please do leave postive feedback for your free answer today!
Nov 10, 2009 | Sharp AQUOS Blu-ray Disc Player
BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
Jul 16, 2009 | Sharp AQUOS Blu-ray Disc Player
Sharp AQUOS Blu-ray Disc Player Logo
3,059 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
