Question about Garden
MAC 130 Chain saw
Has set in the basement for years and will only run if I prime the carb with fuel, runs strong so I am thinking the carb is pluged up
  • 8,404 Answers
Id say you are correct. Take your saw to a repair facility and let them rebuild the carb and install an electronic ignition. That is what I did with my blue Homelite EZ (not the automatic) - runs like a new saw! ... it did cost a couple bucks but well worth it.
I hope you found this info useful
a
Posted on Sep 30, 2009
I replaced gaskets and fuel lines now when i prime bulb gas runs out of carb,also need factory settings for H-L and throttle,i know i messed up somewhere?realy need my saw running,thanks
take apart your carb--sounds like your carb diaphram is not installed right the settings should be
1.5 turn out low jet
1 turn out high jet
that should get it running then some fine adjustment once its running
Sep 04, 2015 | Poulan P3314 14Inch 33cc 2Cycle Gas...
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
Saw starts, wont stay running unless throttling then bogs and dies. changed pluge, gas, cleaned tiny screen in carb, checked diaphrams.
hi
check the fuel pump(not to be tired)inside the carb.the carb could be out of adjustment
regards savumihai71
Oct 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
Sawwon't start or run
On my 110 you take off the front section of the saw body to get et the fuel tank and remove it to get at the fuel line. There isn't much room to work in there so be patient.I'll bet your carb needs new diapragms I bought my manual on e-bay.hope this helps
Sep 08, 2009 | McCulloch Garden
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Mar 25, 2009 | Poulan ES350 16" Chain Saw
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Craftsman 358.352070-14 chain saw start problem
You could try and prime the carburetor and start the saw. If the saw starts for a short while, but dies, than it probably isn't getting fuel into the carburetor, which means that the carburetor either needs to have a rebuilt kit installed, or adjusted or both. This could especially be true if the saw has been around for a while and used quite a bit.
The filter in the tank usually doesn't go bad, but it doesn't hurt to replace it. Usually it is obvious when they are dirty and need to be replaced.
Oct 01, 2008 | Homelite ZR10926 16 Chain Saw
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
