Question about Rode (VIDEOMIC) Professional Microphone
Not sure my VideoMic has the three step pad. Where is it located? Thanks Roger Lindstrom
  • 40 Answers
The pad setting is set by a (very) small dip switch located in the upper section of the Battery compartment. You will need to remove the battery to gain access.
I would reccomend using a toothpick or pin of some sort to change the setting, as the switch is extremely tiny.
Posted on Mar 26, 2010
How to replace the 3.5mm plug from Rode Videomic, it's giving false contact and have to move the plug constantly to get it to work, or replace the whole cable would be better?
First of all, are you sure it is actually the plug ? Could it be the socket into which it is inserted ? Replacing the cable in its entirety would seem the better option, at least to begin with.
Aug 17, 2016 | Rode VideoMic-Camera Mounted Shotgun...
Metal on metal noise when driving. Sounds like brake noise when brake pads are in need of replacement. Sound goes away when the brake is applied. Car only has 20,000 miles on it (2006).
Hello tgiro7: My name is Roger and I will help with your question. The fact the noise goes away when stepping on the brake pedal says the problem most likely is in the brake area. The pads could be worn out even at 20,000 miles.If the noise sounds like it comes from the front remove the wheels and check the front pads. If the pads are bad most likely the rotors are also bad.Same would apply if the noise emits from the rear. When you have the wheels off check to make sure the calipers will slide in and out on the mount pins. Should they be stuck on binding the pads will wear excessively and prematurely fail. The calipers must move freely on the pins. If you drive with your left foot on the brake pedal? The amount of pressure required to apply the brakes and not stop the vehicle is 1 to 2 pounds of pressure. Wont turn on the brake lights but will put pressure on the calipers. This in turn will wear out the brake pads. Another thing to look at would be an out of adjustment brake switch. Reach down and grab hold of the brake pedal. Give a firm tug on the pedal. Should you feel the pedal give and hear a click or two the switch was set to deep and holding the brakes on.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Jun 16, 2011 | Chrysler Crossfire Cars & Trucks
My 1996 ford e 150 5.o the oil pressure gage at cold start gos to low pressure as it warms it goes to normal but when i step on the gas the gage gos to dead low if i let go the gas the gage gos to normal....
Hello royamaral: My name is Roger and I will helps you. I would suspect you have a bad oi; pressure sensor. Should be located down by the oil filter. Just above the filter with a single wire going to it. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Dec 21, 2010 | 1996 Ford Econoline
I am looking for the location of the body control module for a 2002 monte carlo. Can you help?
Hello t_odge1381: My name is Roger and I will help you. To locate the BCM remove the passenger side instrument panel insulator.Disconnect the negative battery cable. (NOTE, Be sure to record the radio access code so you can unlock when done) You should be able to see the BCM tucked up behind the dash panel. Will have three wire pack connectors. You can not just take a BCM from a salvage vehicle and install in your car. Whether it is new or rebuilt it has to be programed to your specific automobile.Otherwise the computer will lock it self out.So to replace it you must find someone who can program the BCM for your car. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Jun 19, 2010 | 2002 Chevrolet Monte Carlo
1994 buick lesabre limited connecting rods torque and head torque
Hello insebard: My name is Roger and I will help. The connecting rods torque to 20 lb.ft. plus50 degrees. The rods torque in 3 steps they are. Step one. 35 lb.ft. Step two tighten an additional 130 degrees. Step three. tighten the 4 center bolts an additional 30 degrees. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Rogerb9c720e.jpg
Mar 24, 2010 | 1994 Buick LeSabre
How can I replace the complete RH wing mrror on my Range Roger P38 Vogue [2000 Model]?
if you pull the door panel you should see some nuts or bolts holding the side view mirror on there should be two or three of them. remove said nuts or bolts and be sure to disconnect the wires going to the mirror so you can remove mirror.reverse the step when reinstalling mirror. hope this helps.
Jan 06, 2010 | 2006 Land Rover Range Rover
Locate O2 Sensors
both these sensors are located before the catalytic converter,sometimes in the exhaust manifold. are you sure that's the problem. Usually they both don't go at the same time. Are they running rich or lean, get back to me and we'll go from there Thanks Ray
Nov 09, 2009 | 2000 Toyota Camry Solara
Need the location of the mapping sensor for a 1994 chevy caprice
Hello l_anderson36: My name is Roger and I will help you. You should find the map sensor at the front of the engine. Located on the drivers side of the engine. The sensor will have a plug with three wires on it.
Should you need further help please just ask. Please rate the quality of this answer. This way we know your answer helped. Thank You for using Fix Ya.Roger
Aug 07, 2009 | 1994 Chevrolet Caprice
Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Feb 12, 2009 | Rode (VIDEOMIC) Professional Microphone
Adaptor needed for boom mic
Look in the manual for this information, contact Panasonic for the adapter
Jun 16, 2017 | Video Cameras
Rode (VIDEOMIC) Professional Microphone Logo
102 people viewed this question
Top Rode Audio Players & Recorders Experts
Jay Plesset
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
