Question about Mtd 22" Yard Machine Push Mower
How to remove and replace rear wheel tire on my mtd self propelled lawn mower model #126-478n134 part #634-0020 tire sized 8 inches.
  • 148 Answers
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Oct 16, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I bought a Yardman 21" Series 560 self-propelled mower used and the belt was missing. What belt does it take? The manual says 754-04080, but I'm looking for a locally available V-belt. Thank you.
Are you sure the belt part number is not 754-04088?
That is a 33 inch belt. I do not know if you need the 1/2 inch or 3/8 inch wide belt. Pulley size would be the key for belt width. I think it is 1/2. Any local source automotive parts or Lawn Mower supply will have this belt in stock. 1/2 x 33 or 2L 33
If by chance I got the belt part number wrong, (I don't think so) just respond here and we can keep searching for your belt.
Thanks for using Fixya.
Kelly
Jun 17, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Stripped screw needs to be removed
hello. You will probably have to drill out these screws enough to use a tool called a screw extractor. That said take a look at this excellent link http://www.ehow.com/how_2078426_remove-stripped-screw.html
Joe
May 09, 2010 | Mtd 22" Yard Machine Push Mower
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mtd 22" Yard Machine Push Mower Logo
905 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
