Question about Garmin StreetPilot 7200 GPS Receiver
How does the garmin 7200 gps mount to a car dash? suction or ?
  • 491 Answers
SOURCE: garmin c330 GPS no tension on mount
Unscrew the tension fully and place washer(s) in the loose areas. Replace tensioner.....Will it hold now?
Posted on Sep 01, 2009
SOURCE: GPS is not getting power on the motorcyclen mount.
Quite possibly the pins that provides power to your Zumo through the mount have corroded after getting wet when the Zumo has been removed. Two ways to prevent this in future, remove the power supply to the mount by unplugging the lead either at the mount or at the battery (or put a switch in) or/and use a product to repel water from the pins on the mount. I remove the mount completely from the bike when not in use which has solved the verdigris problems I was getting.
Posted on Sep 11, 2009
  • 24 Answers
SOURCE: GPS
http://www.fixya.com/support/t3119011-quest_2_antenna_contacts_cleaning
The antenna is on a spring loaded hinge and over time can get dirty where it connects to the gps. I have seen instances where cleaning the contacts helped the performance. Just be careful when removing the plastic endcap on the back of the GPS. There is a small spring that can fly out of there and is lost easily.
Posted on Jan 23, 2010
riceski
  • 1851 Answers
SOURCE: Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
Posted on May 17, 2010
marked
  • 6487 Answers
SOURCE: How to reset Garmin StreetPilot 7200 GPS Receiver
To RESET it turn the unit off, then hold down the menu and map buttons, simultaneously, then turn the unit back on and continue to hold down the buttons down for at least five more seconds, then the unit will power up.
Posted on Jun 17, 2010
My garmin nuvi suction cup gps mount will not stick to my dashboard what will help?
You need a dash disc as the suction mount needs a very smooth surface. Disc are available at GPSNSTUFF.com.
Jul 02, 2014 | Garmin GPS
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
My garmin nuvi 350 suction mount falls from the windshield after several days.
I believe they all do that, I own a Garmin and I bought what looks like a bean bag because I got tired of my suction cup mount falling off my windshield. The nice thing about the bean bag mount is that you can move it closer to you and place it anywhere on your dash. I bought mine on ebay from the Mount Guys they have a big selection of mounts for all types of GPS's take a look you might want to make the change too.
I hope this helps you out and if it did please leave me some feedback
Apr 03, 2011 | Garmin GPS
I have purchased three of these products from this company. I am sick and tired of this navigation system falling out of the window while I am driving. I am a salesman that purchased this product in good...
Brian - you should contact Garmin directly at www.garmin.com - this site is not affiliated with Garmin in any way. I'd suggest that you secure the GPS to the center of the windshield or use the semi-permanent dash mount instead of suction cup mounting to the windshield near the driver window.
Jun 30, 2010 | Garmin Nuvi 760 Car GPS Receiver
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
My problem is how to use the Dash moount disk for the Garmin 350? My real problem is getting the answer?
The dashmount disk has a sticky side that should be pealed and stuck to the dash - then use the windshield sticking cup to stick to the dash mount smooth side...
Jan 13, 2009 | Garmin Suction Cup Mount F/ Nuvi 350
I have a Garmin Nuvi 310 and the windsreen mount keeps falling off the galss irrespective of how much I clean the window and the suction cup. I have heard this is a common problem... I sent an email off...
Have you tried wetting the suction bottom before applying it? Also, try looking into a Garmin friction mount. It's a heavy bean-bag like mount that is filled with lead pellets and has a rubber bottom that won't slide on your dash. It's easily removable, legal in all 50 US states and you'll prevent damage to your Nuvi as your Nuvi won't fall from the glass and hit the dash.
- Jim
Dec 03, 2008 | Garmin GPS
Suction cup problem
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Nov 05, 2008 | Garmin nuvi 350 GPS Receiver
Installing my new street pilot
It is a mount for your dash that your suction cup mounts to just paste it to your dash ans put the suction cup on it and install your unit
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot 7200 GPS Receiver Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
