Question about Mitsubishi WD-62525 62" Rear Projection HDTV
We have a mitsibishi WD 62525 TV that has a green blinking light that will not reset. It has had multiple repairs. Dilemma: Repair or Do not resuscitate? Do you know of anyone that buys these TVs?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
All will tell you what a hard set this is first you might have a leaky tube might have leaked along time ago one or two drops of fluid and now is corodeing your board It can be cleaned up and brought back to life someone realy needs to look at it to determine this
Posted on May 05, 2010
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The green light labeled "Timer"
u have a bad control box to repair this unit is better to hire a tv tech , total cost may be $500
Nov 03, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light
Have you tried the reset button on the front of the tv, on the far left I believe? That probably won't solve your issue since this has been an infamous problem for Mitsubishi.
If the reset button doesn't work the most probable fix are the (12) 1000uF capacitors (4 on each board) on the Power Supply, FMT board and the DM board. There are several other replies from reputable repair people on this site for this problem on the wd-xx525 series.
You probably just need to replace the DM capacitors. You can get the V26 DM repair kit from www.tvrepairworld.com which has the capacitors and the Cd with instructions
Jan 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking green and won't turn on
Ur BD power board have a dead capitor.
Go to TV Repair World in the website.,buy ur tv name model kit.Repair it ur self, if U know how to do soldering.
Aug 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Jan 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
