Question about HP Compaq Presario C304NR Notebook
Tryed to turn laptop on and now it is saying operating systems not found
    President:
  • 828 Answers
Please check your Hard Disk Drive in the BIOS is still functioning. At the BIOS Booting Setup the should be ON to boot your Operating System.
Try and try again.
Posted on Sep 30, 2009
  • HP Master
  • 8,404 Answers
Check your removable drives for a non sys disk (floppy or CD). Remove the disk and try again.
If it still says system not found, you will likely have to reload your OS.
Let me know what happens
a
  • 788 Answers
Try removing the battery and power connections.
Next, removing the Hard Drive on the bottom and reseat it.
Next, while unit is unplugged and battery removed, flip the unit over and hold the power button down for 30 seconds.
Re-install the hard drive and battery and plugin your A/C power adaptor.
Try to start unit. If the unit display's a message, date and time changed, continue thru and make whatever changes.
Don't forget to save your changes.
Unit should restart and go into your operating system.
If not, you may have a dammaged Hard drive and you should have it checked.
I hope this has helped you and the unit comes back OK.
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: my hp pavilion 4200 i took the hard drive out and
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Posted on Mar 08, 2009
dreager
  • 119 Answers
SOURCE: Hi, the laptop will not boot up. no operating system found
Put in Windows CD to see if it picks it up, go to install screen to see if it will start to install, if it does then it is finding your HDD. Try the repair option then. Your windows may just be corrupted.
Also try hitting F8 for other options, e.g. Safe mode to remove corrupted drivers.
Posted on Mar 13, 2010
Hello my laptop keeps saying no operating system found
This is a problem with recognizing your hard drive or the Operating System installed on the hard drive. Put your Windows 7 or Vista CD into your drive and restart, booting to the CD drive. Try to repair your startup problems. If this does not work, you may have a hard drive failure.
Feb 10, 2015 | Toshiba Satellite A300-0CF035 Notebook
Say operating system not found
Reset bios to defaults and try again. If that doesn't work then its possible that your hard drive has failed.
Nov 08, 2013 | Samsung R580 Notebook
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
My toshiba nb520' operating system is gone when i open it says operating system cannot be found.
The hard drive in your laptop is bad and will need to be replaced, first remove hardware and carefully reseat it back in place, sometimes the hard drive will restart, "long shot" if still nothing! have it checked for possible replacement.
Apr 12, 2012 | Toshiba Computers & Internet
When turning on my laptop it says operating system not found what do i do
have you tried re-installing the operating system?if not try it.good luck
Mar 18, 2012 | Gateway 400SD4 Notebook
Help
Unfortunately it sounds as if the hard drive is clicking and not detecting because it has failed. At this point you will need to locate the operating system media for your system and purchase a new hard drive and start from scratch.
Jun 17, 2010 | Sony VAIO VGN-N250E/B Notebook
Operatig system not found"
Try reinstalling the operating system, if fail, try running checkdisk on the HDD. If problem persists, replace the HDD.
Cheers!
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Which OS were you using? Can you boot from the install CD/DVD and try to repair from there? Can you go into setup at boot time and make sure your hard drive is recognized?
Lou
Aug 24, 2008 | MetroBook Computers & Internet
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
HP Compaq Presario C304NR Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
