Toshiba TW65H80 TV Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Objects are shadowed on screen and color seems to be seperating
Picture arrows are off by nearly an inch and each is a different color blue and red
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Sep 30, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
149843
Points
2098
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
2helpful
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
I have a 42 flat screen projector. The picture i see doulbe the normal color of the letter. then behind the letter they show up in different color. Then when there people on the screen or object there...
The colors have to be aligned most systems have a calibration screen with in the setup menu
Follow the instructions .... this is a common issue
LB
Printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Colored shadows on sides of subjects
Convergence problem... most likely caused by convergence ics
1helpful
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
