Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top load bearings seized in drum pulley , freed bearings and greased.now drum spins free but hard time to start turning is it possible motor trouble ?
  • 335 Answers
I’m an owner not a repair person but I will pass on my FAV6800AW Clutch issue experience.
With an empty Wash Basket open the lid and with one finger (pinky) you should be able to rotate the wash basket with little rotational resistance. I’m not sure how else to describe normal Wash Basket CCW rotational resistance in the Spin direction of the system. In my eyes any more resistance than that would indicate some binding in the system. If the roller clutches were seized as you describe I would replace the clutch but lets discuss further.
How much CCW rotational resistance did you detect with the clutch out? Did you follow this post for the One-Way Roller clutch bearing clean up? In that post I discuss checking for CCW rotational resistance prior to removing the Clutch. Does your FAV6800AW use the upper Roller Clutch Bearing Ring as I show in this post? If so what condition was it in?
The Outer Tub bearings may be adding to the CCW rotational resistance (Leaking Tub Seal). You could remove the belt off the Clutch pulley the motor should spin freely by hand and I feel you will find that is not causing the increased CCW rotational resistance with the above check.
I would drop the clutch out again and check the Wash Basket CCW rotational resistance. That would give me a feel if the Outer Tub bearings are adding to the CCW rotational resistance. If the Wash Basket rotates CCW freely I would replace the clutch with the one I recommend in this post.
Post back if you have questions and maybe we can have another forum member speak to this issue. I could be over looking something in troubleshooting. Good Luck
Posted on Sep 30, 2009
Maytag Neptune tl FAV8600AWW wont spin CCW ON FINGER TEST
Possible that the spindle or the bearings are jammed in this case. Check this link and reset the drum and bearings: Drum
Jan 19, 2013 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl top loader is stuck on 23 minutes and just keeps going back and forth. There are no error messages. and water is sitting in it. Any ideas?
don't visit this site very often and I don't want to troubleshoot FAV6800A or FAV9800A issues here.
I have two DIY sites that I try to provide owners support as a knowledgeable owner.
You problem is related to a Clutch Issue. Google these keywords ""[FIXED] Maytag neptune FAV6800aww wont spin""
It's a long post it was difficult for me to pull accurate info from the owner for the issue. Fo him the Upper One-Way bearing on his machine was seized. All of these machines are ready after 6 years + of operation are ready for a Outer Tub rebuild. It's a few hundred dollars to do if you have to replace the Clutch Pulley as part of the process.
But one step at a time read the thread [FIXED] Maytag neptune FAV6800aww wont spin and see if this is a DIY project for you. It
Jul 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Machine stopped abruptly full of water. smelled like burning.
That could be a Locked Up Clutch Pulley One-Way Roller Clutch bearing my 1st choice Or a tranny lock up if this happened during wash/agitate part of the cycle.
If this happened in Spin Cycle it could be seized Outer Tub bearings.
If you want to DIY see this post
I have a neptune that continues to beep and do its own thing. do you thinks it's the computer board?
Feb 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Kelly,
“”Yesterday it started again with the same dc codes. Noticed this time that it was banging all 4 sides of the machine during the wash cycle.””
Can you do a Quick Wash cycle with minimal settings Soil Level and Spin settings with an empty wash basket.
So after water fill if you raise the top of the machine and observe the Wash Basket you should see the tumblers rotating only. I think from your description you may observe the Wash Basket rotating CW and the tumblers rotating…..is that happening in Wash/Agitate cycle?
If that is so it seems to me that the Spinner Shaft Coupler (my name for it) is seized into the Clutch Pulley One-Way Roller Clutches Bearing in the Clutch Mounted One-Way Roller Clutches bearing mounted in the white bearing plate. And or the Upper One-Way Roller Clutches bearing ring if you Series 12 machine does use the Upper Bearing ring. I know the Series 10 and 11 use that upper bearing ring.
Does you Series 12 FAV6800A Clutch Pulley use the Upper One-Way Roller Clutches bearing ring?
Have you used my Clutch Fix post for reference on maintenance and or replacement of the FAV6800A/FAV9800A? In that post I have a comment labeled “”Let’s demystify dC and uC error codes plaguing the FAV6800A and the LCD Flavor FAV9800A””
I would drop your Clutch Pulley out and verify that the Spinner Shaft Coupler will rotate CW &CCW in both the Clutch Pulley One-Way Roller Clutches bearing white bearing plate and the Upper bearing ring if you machine does use that upper bearing ring.
If you can let me know the results? I will try to help…..Rich
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL FAV6800AWW stops on the spin cycle (~11 min). I can see and hear the tub tumbling kind of hard even though it has small amount of clothes. I already removed the clutch and lubed with...
Thank you for posting your Model number very much appreciated. Did you follow my Clutch Fix post for the clutch maintenance you performed? Did your Clutch Pulley use the upper bearing ring as I show in that post? When you stop on Spin Cycle do you have an unbalance error code such as dC or uC. What are the first two digits of your Serial Number it will be 10 thru 17 range. I?m an owner and will I?ll try to help?..Rich
Apr 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B leaks. The leak is from a small hole in the outer plastic drum. The hole is at the six o'clock position where the large pulley that turns the inner drum is attached. There is a...
You most likely need a new outer tub,the bearing seal is shot eventually it will get gradually louder in spin if it hasn't already,you can try having the seal replaced and that may stop the leak but the damage to the bearing is already done.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
TUB WON'T MOVE , EVEN BY HAND
TAKE THE BACK COVER OFF, EITHER THE MOTOR IS SEIZED UP OR THERE ARE SOME CLOTHES STUCK BEHIND THE DRUM
May 29, 2009 | Washing Machines
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag 6500AWQ
The outer tub bearing. This bearing is under a lot of stress and tends to wear out. Check and see if there is excess play in the drum. Move the drum all around. Also if you remove the back panel plate you can access the main pulley. If this pulley has any side-to-side or top-to-bottom play then the bearing is bad
Dec 29, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune FAV6800AW Top Load Washer Logo
226 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
