Stereo receiver crackling noise
When adjusting (turning) the volume on my receiver (20 yrs old) I receive sound and a crackling noise from the speakers whether it's radio, CD or casette. If I play with it enough I can get it to a level where the sound is working with no crackling or interference. Is there a simple fix to this? Perhaps I can clean some contacts? Any suggestions would be much appreciated....thanks in advance
    New Friend:
  • 13 Answers
Open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Posted on Aug 13, 2017
  • 494 Answers
SOURCE: My sony icf 7600 AM/FM/SW/radio can not catch any channel.
Sony radios of this era had notorious capacitor problems.... also several other brands were affected. These capacitors were underrated and the technology to make them was not at it's best back then. The cure is to replace the capacitors on the board with new electrolytics. About 28 of them need to be replaced but the big problem is to find someone to do this. the original capacitors are surface mount and must be removed and new radial lead caps put in their place, some are rather tough to get at and the new ones have to be placed carefully. My SONY ICF-SW7600 now works as new and maybe even better!
I have done this myself as I have skills working with surface mount capacitors. I offer my services to those who cannot find service for their radios. Please email me for details, I am not into making bucks on this, I just want to see these radios kept working and bringing enjoyment to their owners.
Good DXing Rod KB8DNS (also copied and paste)
Posted on Jun 17, 2009
  • 3130 Answers
SOURCE: Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Posted on Mar 16, 2007
  • 556 Answers
SOURCE: sound interference
As you there seems to be interference via sound as the picture is fine. the interference is a crackling noise& tv is old 1 CHECK SPEAKER 2 so in that case tunning in sound section is disturb get it tnnned. 3 any components in sound section has done defective(SIF)SECTION. 1 CHECK SPEAKER not matching or paper torn or paper cone hard.
Posted on Sep 18, 2007
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
  • 1689 Answers
SOURCE: volume control
Go to the local TV service store and ask the tech if he can clean the control with some contact cleaner.
If the cleaning does not fix it, then there may be a cold solder connection under the control, or the control itself may be defective and require to be changed.
Jerry G.
Posted on May 17, 2008
Distortion in speakers when i turn the tuner knob it hits some hard spots they quits
Turn the stereo off, then quickly turn the volume knob back and forth for about a minute to get rid of most of the grime that is causing the static. Then turn it back on. if that doesn't work...
You can try cleaning out the potentiometer.
If that still doesn't work. replace the potentiometer
Feb 25, 2016 | Audio Players & Recorders
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Sep 21, 2008 | Car Audio & Video
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
I have a yaesu ft-736r with no audio
Hi Jermaine,
It transmits, but no receive, are you sure, have you tried playing around with the volume control?
If, so did that make any crackling noise? If so, then this is due to lack of use of the volume control, many radios, including the old transistors with dials, would make crackling sounds when you adjusted the volume, and as I say, this is due to lack of use, So if this is the case and to get your receiving, turn the volume control up & down fully for a few minutes and while doing so your radio might receive a transmission that will be loud, quiet, loud, quiet, etc., as you play with the knob.
Keep doing so until all crackling has disapeared.
Do this often as possible when firing up your radio for the day, the more use these controls get, the better.
I hope this has answered your query.
May 29, 2012 | Yaesu FT-736R
Speakers make crackling sound and sound goes in and out.
If the sound crackles when the volume is turned up or down there may be an issue with the volume switch. If the volume is going up and down on its own, I would recommend that you need a new unit as the cost would be greater to fix, then to replace.
Dec 03, 2010 | Sony STR-DG800 Receiver
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
I have an old onkyo a-8067 reciever and only the left side speakers work. A while back the right side was fading and now it doesn't work at all. I also have a sony STR D1015 home theater receiver that has...
Fixed the Onkyo. Took apart the balance adjuster and rebent the feather-like things inside so they made contact. Clamped it back together and it works fine.
Nov 26, 2008 | Audio Players & Recorders
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
Mar 14, 2007 | Sony STR-DB840 Receiver
5,029 people viewed this question
