Question about Garden
I have a GX75 riding mower and the deck is not leveling out. No matter what level I put it on (1-4) it always ends up with the front of the deck lower than the back by at least 3/4 of an inch. This is causing (I think) the mower to cut uneaven and the yard looks bad. Help! Jeff
    President:
  • 1,627 Answers
If you have verified that the deck is level then you will need to replaced the spindle,if the deck is'nt level ,adjust the leveling nuts on the arms it hangs offf.
Posted on Sep 30, 2009
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
How do I level the deck on a John Deere X500 mower
FInd and buy a deck level guage (makes it so much easier) photo.25191349-sc2hyhwnmj3wm0xvqhiyjoyo-1-0_0.jpgAdjust the front tire pressures to 14 psi. Set the rear tires to 10 psi. Make sure that the mower is on level ground,concrete driveway or garage floor. Set you deck height knob to 2.5 inches. Move the blades to where the blade tips are pointing to the side of the mower deck. Level the deck side to side by adjusting the lift link nuts,15mm or 17mm wrench. Get the side to side as level and possible and close to a number or mark on the guage. Move the blade tips to the front of the mower deck. Check the front to back and have a 1/8" to 1/4" lower on the front of the blades than the back. 18mm and 19mm wrenches for the front adjusting bracket.
Oct 06, 2014 | John Deere Garden
Ahow to adjust the deck height of a craftsman riding mower
The deck should have a handle to raise or lower deck. To level the deck you can look at the front of the deck attachment and should see a threaded rod going through a plate in front bottom of chassis. Tightening this nut will raise front end and vice versa. I hope this helps.
Aug 11, 2013 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I have a 20 HP Sears riding mower with 42" deck. Something has caused the right side of the deck to sit lower. It literally sits on the ground when lower to #1 position.
There are deck leveling adjustment bars located on most lawn tractors, most are equipped with a large plastic wing nut. There will be one on each side, with the mower off, lower the deck to the lowest position, loosen the wing nuts on each side, then re-tightnen. There is also a possibility if this is not the way your deck is levelled, there will be a deck hang wire/rod, however those are usually found on zero turn style mowers.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
How do i level the deck on a murray riding mower model number 46576x92 twin i/c?
Mtd riding mower: right mower blade cutting uneven, but don't see problem
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Sep 18, 2009 | Garden
The deck tilts down forward so the guide wheels are always in contact with the ground. how can i level the deck so it raises and lowers equally front and rear?
a mowing deck is suppose to be lower in th front than the rear usually 1/2" to 3/4" difference however if you need to adjust your deck you can go to www.deere .com and search for your owners manual and the procedures will be in the owners manual
Aug 29, 2009 | John Deere Garden
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Garden Logo
173 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
