Question about Toshiba (4CH-VOUT) Sound Card
No sound from built in speakers
No sound at all from built in speakers. All volume controls are "high" and nothing has been checked as muted.
  • 3 Answers
Have you checked on your hardware list to make sure the device is functioning properly? It may have something to do with the driver as well.
Posted on Sep 30, 2009
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
My advueu monitor has built in speakers which are not working now. do not know what is wrong
First--have the speakers worked before? If so, be sure the speaker wire is plugged into the green hole on the back of the computer and also plugged into the monitor.
Is there a volume control on the monitor? If so, be sure it's turned up.
Are you speakers muted? Check in the sounds icon in the control panel (there could also be a little picture of a speaker in the system tray. Many times people mute the speakers and forget they did it.
Also in the sounds area of the control panel, be sure the volume is turned up.
Oct 06, 2010 | Computers & Internet
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Saadddd.no sound????
Are these built in speakers? If so, check the speaker drivers and the application that control the speaker volume etc to see if it is actually muted.
If they are external, check the power source.
Nov 05, 2009 | Acer (90.18612.36B) Computer Speakers
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
No sound in windows XP to my laptop.
A couple of things to check. First I will start with the obvious, is the volume turned up? Next you need to check that the system sound is turned on. Click on Start>settings>control panel. Then double click on Sounds and Audio Devices. On the first screen make sure there is NO check in the box next to Mute and that the slider under device volume it at high. Click the advanced button and make sure nothing is muted here and all sliders are at the top. Back at the main screen click speaker volume and make sure those sliders are on high. Finally click on the Sounds tab and make sure the Sound Scheme is set to something other than no sounds.
Mar 27, 2009 | Toshiba Satellite A135-S2276 Notebook
Altec lancing 221 pc speakers are not working.
right click in speakers icon and open volume control----check volume control fader in up position-------check that nothing in mute setting and remove mute where ever you find it.-------confirm that you plug speaker jack in right place(line out).-check your sound driver and confirm it is ok.
Aug 06, 2008 | Audio Players & Recorders
Volume diminishing
Try other speakers with the card.
Most speakers have an amplifier built-in them. Most of the time they go slowly, which may be the case.
Dec 15, 2007 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
