Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore top loading washer. I did a load and the laundry came out somewhat damp - I spun that load a second time. Then I tried a 2nd load. When i came back into the room, I smelt burning - I had thought something was on fire (not burnt rubber - more like plastic) and the washer had just stopped. It was full of water, just past the rinse cycle, about to start to spin. Now it won't work at all. Any ideas?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The first thing I'd do is pull the cabinet off and check for a broken / damaged Motor Coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
OR
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The coupler is a three piece unit that is designed to break if there is too much load on the motor or transmission. The "burning" plastic that you smell may be the plastic pieces that mount on the motor and transmission rubbing against each other.
If the coupler is OK, a couple of other places to check are the Lid Switch, Timer and finally the transmission.
Following is the Whirlpool installation and maintenance guide (PDF) on top load direct drive washers that may give you a better idea of where to look.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Sep 30, 2009
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have a kenmore oasis elite top loader which is made by whirlpool. we have replaced the machine control panel and the electronic panel behind the dial. the washer is skipping time during the cycle then...
Hi
Thanks for using FixYa. Error oL means overloaded and it flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. To clear this error you’ll have to open the door lid to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
I have a kenmore 80s series top loader washing machine. The water does not drain all the way on the spin cycle. I have to always run a second spin cycle
I know this sounds goofy but it sounds like the machine has been over loaded a few times and each time the machine is over loaded it makes the springs weaker. That makes it easier to overload with less laundry. Try to put less clothes in and see if that helps. Good luck.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Jun 14, 2008 | Kenmore 24642 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
