Question about RCA F32650 32" TV
Tyjeu when i plug my tv in it makes a high pitch noise and doesn't even power up
  • 647 Answers
The high pitch noise is comming from the power supply (SWPS) as it attempts to start but there is a short or excessive load. The Horizontal o/p transistor is likley short. This type of fault is economical to repair but should be left to an expert TV repairer.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour
Posted on Sep 30, 2009
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Wont turn on and high pitch noise
Looks like the printers internal electrical components have gone. if there is a tranformer in your printer then that is making that noise. or else even the motors might also be gone.
my strong suggestion take it to any authorized service personnel
Apr 20, 2009 | Computers & Internet
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
RCA F32650 32" TV Logo
126 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
