Question about Whirlpool Royal A-909 Bathtub
New house, just over 1 year old, came with Royal whirlpool tub. I never used it. Today when I tried to start it, it just does not come on. I donot have a manual and cannot find one online. Any help please
    President:
  • 1,564 Answers
First you want to trace and check if the unit is tripping the circuit breaker in the fuse panel of the main house. Next you want to take the top two bolts of the control box(within the body front of the tub) and remove them. pull the cover downward towards the ground. Next you want to trun a hairdryer from an extension cord(make sure your feet are well guarded from the wet surface should this occur. Using the hairdryer, dry all of the exposed components of the box and it's housing. This is precisely what a hottub repair reprentative would charge you $100-$150 to do, not including travel time. See I just saved you more than you'll pay for this info...lol. Put the screws back in and close up the body of the tub. You should be good to go. Thank you, Dana
Posted on Sep 30, 2009
How do you install a new on/off switch in a royal whirlpool bath?
The switch is located on the back of the pump. If you have access to the pump and you can see the tube coming out of the black box on top of the pump you might have a chance of changing it without pulling the tub, If you do not have access to the pump, one will have to be made or pull the tub for repairs. If the pump can be removed this might also make the repair go easier. The switch is available at most pool or spa stores. If you are uncertain about doing this repair call a Jacuzzi certified repair technician to do the job.
Jul 06, 2014 | Whirlpool ROYAL BRB826 Corner Tub, Jacuzzi...
Black debris is coming out of the jets when you start it up. What is this and how do I get rid of it. Thanks Gord
If the tub is more than 5 years old the rubber pump impeller could be disintegration.
If the debris just seems to be dirt then fill the tub above the intake with HOT water ... then add some dish washing detergent to the water ... run the pump about 1/2 to 1 hour
Feb 25, 2011 | Whirlpool Home
Sears gave me an estimate of $1439.65 to repair machine by replacing the following: 1 SUB TUB-OUTE - 213.82 1 GASKET - 12.16 1 SUB TUB-OUTE - 411.91 1 SUB BASKET - 492.69 1 BELT ...
Check your warranty. We just had that problem, with the exact same parts replaced, but the outer tub has a ten year warranty, and the basket a lifetime warranty. We just paid labor and for one belt. Our washer is also almost eight years old.
Oct 09, 2010 | Whirlpool GHW9100L Front Load Washer
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
WASHER TUB SITS LOW AND TO THE SIDE, LOADS OFF BALANCE...
GAVE UP AND BOUGHJT A RECONDITIONED WASHER FOR $100 TWO DAYS LATER. I THINK I DID WELL, THE GUY TOOK THE OLD ONE AS ATRADE PLUS THE $100. THE NEW ONE IS 4 YEARS OLD. THANKS ANYWAY!
Jan 28, 2009 | Washing Machines
Whirlpool does not work
I think it is manufatured by Nordic.?
this link should help you will all the installation use and repair.
http://www.nordichottubs.com/owner-center/default.aspx
let me know if this is not the one.
please post additional comments in this thread.
Nov 11, 2008 | Whirlpool Royal A-909 Bathtub
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Royal A-909  Bathtub Logo
203 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
