Question about Freezers
I bought a used model MFC05M3BW5 chest freezer. I
I bought a used model MFC05M3BW5 chest freezer. I opened the drain to defrost it but the water did not run out. Is there a "knock out" plug in the drain and how do I open it up to drain correctly?
  • 308 Answers
Please see attached link for more info, but it appears as though your model has both an internal and external drain plug. Hope this helps
http://www.youserguide.com/wiki/Electrolux_216657700en-007
Posted on Sep 30, 2009
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
How do u defrost a ge chest freezer
Don't hit or punch the freezer walls ,just unplugged and let the frost melts and this water will go through the drain down to an evaporative pan.Make sure the drain is not clogh if it is clogh put hot water into it or blow it with air pressure.
Aug 13, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Water drains into fruit bin. not drain hole.There is no blockage in drain hole that I can see.F/F Liebherr premium model
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
May 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
How to unfreeze the deep freeze, and which of the two type is more reliable,.,., tc tnx and god bless
There are numerous methods to defrost freezers, from placing buckets of hot water inside to using hair blowers. I like to unplug freezer, unload freezer, use a plastic putty knife to scrape excess frost off walls if in a bit of a hurry, and to let it just thaw out, using the drain port in the bottom of the freezer, hooked up to the garden hose adapter that came with the freezer to run the water to a drain.
The chest freezers are a bit more reliable than an upright (in my opinion) and are more energy efficient, but do make it harder to find and organize items in the freezer. FYI: Virtually any brand name freezer on the market in the US was built by either Frigidaire in St. Cloud, MN, W.C. Woods Co., from Canada, or Haier Co. in China.
Mar 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezers Logo
212 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
