Question about Element Electronics FLX-2610 26 in. LCD HDTV
My Element flat screen tv often flashes a blue screen with an error message during television viewing. The messages are usually different with a few letters and numbers. It seems to happen more on certain channels than others.
SOURCE: Program Blocked errors
No, the problem is not fixed. I do not want to subscribe for any plan. Thanks
Posted on Nov 15, 2009
  • 126 Answers
SOURCE: I recently viewed a few solutions to a problem
did you try shopjimmy.com?
Posted on Oct 26, 2010
  • 17 Answers
SOURCE: every so often my element flat screen tv model fx
turn off close caption all the way in menu
Posted on Nov 10, 2010
gopakumarg43
  • 75462 Answers
SOURCE: 19' flat screen TV slow
Hello
You haven't specified the Brand or Model number of your flat panel tv. Yet I'm answering to this enquiry, assuming that yours' is an ordinary 19" flat screen TV.
For most the TVs, this fault will be due to the base socket of the picure tube. You can locate this socket at the picture tube base card, directly soldered to it. This socket is otherwise commercially known as picture tube base. It connects the picture tube pins to the rest of the circuit, and can be detached from the base of the picture tube by a light backward pull.
You just open your TV and pull out the base card from the picture tube neck. Care should be taken not to shake the board sideways or up and down movement, as this may damage the pins of the picture tube, or can cause a crack in picture tube neck. The neck of the picture tube is very thin, relateve to other part of it, and have a chance to break easly. So be very carefull when detach the board out of it.
Resolder the base socket out of it, detach the Focus wire attached, in some cases, there will be an other wire too, screen voltage wire. Go for a same type and pin confuguration. You can select whichever companys product; provided the pin confuguration. The material used to manufacture it is very important. It should be of good quality; otherwise the fault will occur within a short period of time again.
If you wants any more assistance, get me through Fixya. Ok.
Posted on Nov 25, 2010
jhinsincity
  • 616 Answers
SOURCE: Have an element flat screen tv/40" LCD. ELCHW402
2345
Posted on Apr 30, 2011
I have a 1 year old 50 inch element tv that flashes a blue screen randomly seconds or minutes apart. It doesn't happen every day but often enough to be irritating and be a problem.
if you have the whole screen going blue it could be a simple loss of input, if you are viewing through a cable or satellite box check and or replace the interconnect leads, and check for loose connections, if there is a spare input port on the TV not used switch the cable/lead to there for comparison.
Jan 06, 2016 | Element Televison & Video
Sony TV problem.
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Mar 06, 2008 | Video Game Consoles & Games
My 19" Element TV shows message "Sorry for your inconvenience..This channel will return shortly.
Element Electronics tv error codes Questions & Answers ...
www.fixya.com > Forum > Tags > tv error codes
Element Electronics tv error codes related problems. ... I need help programing mycraig 19 in flat screen tv with my universal remote control model TVG1307, can someone help ... I need the code to program the remote so i can operate my tv.
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
this is a vid im attaching to my email to custamer support to try and fix my ... Show more ... Element HD TV unboxing and review, buyer beware!
Dec 25, 2015 | Element Televison & Video
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
When i turn on tv runs a while and screen goes blue. turn off power and works for a few minutes and does it again. HOw do i fix it?
To discard or not should be based on cost to fix--blue screen usually means no signal is seen by set--could be minor or major repair--call a few shops and try to get a ballpark estimate.
Apr 08, 2012 | Element Electronics FLX3711B 37 in. LCD TV
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
I plug in tv and all I get is a blue blinking light.
That is an error code. Count the number of flashes and then look in the owners manual to see what the message means.
Jul 04, 2011 | Protron PLTV-32 Television
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
XBOX READING E68
This error code appears in the center of a black screen on the television or on the monitor. If you receive a different error message, you are experiencing a different issue. For more information about what to do if one red light flashes and you receive a different error message, click the following article number to view the article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/)
Mar 17, 2008 | Video Game Consoles & Games
Console reads E 68
Mar 17, 2008 | Nintendo Game Boy Advance Console
Element Electronics FLX-2610 26 in. LCD HDTV Logo
60 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
