Question about GE Ovens
We have a GE built in oven, model # JCKP13GP-1. The oven, after operating for an hour or so, shuts down. Sometimes the signal beep goes off when this happens but not always. Any hints on what this could be caused by?
  • lucillevince Jan 07, 2012
    I WANT TO HAVE THE MANUAL FOR THE OVEN : MODEL JCKP13GP-1
    THANKS
    Guru:
  • 310 Answers
We see a symptom like this sometimes due to a failure in the electronic clock/control. Although, by the time we get the control in for repair, it is usually shutting down after a minute or less. You could also have an intermittent temperature sensor or intermittent wiring to it or the door lock, so you should consider that first. The control board for this unit has been discontinued, but we repair them at www.fixyourboard.com.
Posted on Sep 30, 2009
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
Oven shuts off 10 minutes into self clean cycle or while broiling
check for loose connection on the door sensor or micro switch you ay need to change the micro swich if faulty
Jul 28, 2010 | GE 30" Built-In Single Electric Wall Oven...
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
GE JTP15 oven shuts off
Mine was doing the same thing all day today. All I know is when it was cool I lifted up a bit on the lower burner an inch or so, and set it down. Next thing ya know, you guessed, it, it's working again...Not sure what's doing it, will keep checking for a solution.
Jun 10, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
243 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
