Question about Aiwa CDC-X144 CD Player
Hello.. I have the Aiwa CTX428M model and need a faceplate. The current faceplate is not lighting up so I can't see the information. What do u suggest? I found a ctx429M faceplate will that work? Is it best to get another unit or can this problem be solved? Thanks
2 Suggested Answers
brgary3
  • 10 Answers
SOURCE: Which Aiwa remote control unit to buy.
I HAVE GOOD NEWS, YOU CAN GO TO WWW.REMOTES.COM WHERE IT SAYS SEARCH BY MODEL NO., PUNCH IN CXNA505, THEN ENTER, ONCE YOU GET THE MODEL NUMBER OF THE REMOTE, YOU CAN GO TO EBAY, AT WWW.EBAY.COM AND MAYBE GET THE REMOTE FOR A LOT CHEAPER.
Posted on Feb 17, 2015
I have an Aiwa cx-nma545 w/o the remote. What is the model number to the remote itself? Or do you know how I can replace it?
http://m.ebay.com/itm/AIWA-RC-ZAS05-AUDIO-SYSTEM-REMOTE-CONTROL-CXNHMA86-CXNHMA86U-CXNHMT75-/331729077190
Remote is no longer available from Aiwa nor most remote resellers. Ebay is your only source. The above link is to one available currently on ebay usa
Aug 18, 2016 | Aiwa Televison & Video
I need a replacement remote control for my old AIWA hifi mini system Model No CX-LEM50K
They do. If you're in the UK you can try Curry's Partmaster for replacements. Sorry to have to inform you that most replacement remotes are not cheap though, as the makers know when they can spot a money making thing. Everyone sits on or drops remotes!
Feb 22, 2013 | Audio Players & Recorders
Need a faceplate for aiwa CDC-X304. Where can I get one?
ok I have the face your looking for? CDC-X304 face
May 21, 2012 | Aiwa CDC-X304 CD Player
Right i have an aiwa mx-n9 + mx-n7 systems mx-n9 keeps
These little fans are driven by fluctuating currents not DC current. It is a problem with the circuitry the drive it. The current are pulse width modulated, which is how the speed of the fan is controlled.
Jul 01, 2009 | Aiwa Audio Players & Recorders
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Wire harnest order
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
Nov 04, 2007 | Aiwa CDC-MP32 CD Player
Aiwa CDC-X144 CD Player Logo
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
