Question about Kenmore Refrigerators
My ice maker on my fridgidare pro series plhs2692db9(2005)
My ice maker on my fridgidare pro series (2005) will only make 1 or two batches of ice, i tried to use the extra ice function and no luck The meatl ice detector bar(small bar that detects the ice) moves freely also
watugot
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
aborcass
  • 2651 Answers
SOURCE: Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Posted on Mar 01, 2008
  • 1122 Answers
SOURCE: Kenmore 253.54703405 ice maker does not reset
a gear under the cover turns the arm,i think you should find a appliance part store in your area and replace,around $50 for brand new one,thanks-mike
Posted on Jul 12, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
DirtyOldGit
  • 5 Answers
SOURCE: Samsung Refrigerator Model RS2533SW - Ice Maker Stuck
I did this but found it still didn't work till I turned the fridge off at the mains. Now working fine. Many thanks
Posted on Aug 10, 2009
Ice maker makes one-two batches of ice
Either the arm has something causing it to stick or the actuator switch is mis-alligned or faulty.
Sep 05, 2014 | Kenmore Refrigerators
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
Hoshisaki makes ice to slow
not sure what "too slow" is to you. Hoshi machines are designed to make more ice per batch but less batches per day. It is not unusual for a batch to take 25-35 minutes for one batch. The 1600 makes a lot of ice per batch. Look for some obvious things. If air cooled condenser, be sure it is clean. Make sure the water to the machine is not Hot water. It is not unusual to get Hot water feedback in a restaurant environment. Check for a leaking water valve. A sticking float can also cause long freeze cycles. Start with that and let me know if I can be of any further help,.
Jun 04, 2012 | Hoshizaki KM-1600S Stackable Crescent...
Not making ice fast enough
Good day,
Assuming the cubes it's making are the proper size, the speed the ice maker produces ice is determined by the temperature in the freezer.
When the ice maker harvests a batch of ice, an electric heater heats up the whole ice maker.
There is a thermostat embedded in the ice maker. It must cool back down to approx. 12 degrees before making the next batch. The colder the freezer compartment, the faster the cycles.
If the cubes are too small then that is usually caused by a blockage in the water filter if your unit has one, or the water valve that feeds water to the ice maker is getting weak, or lastly the water supply to the machine has become partially restricted.
On extremely rare occasions the thermostat built into the ice maker goes out of calibration which can cause a delay in cycling and requires the ice maker to be replaced. But again, it is a very rare occurrence.
Oct 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
No ice
Pour some water in the ice maker. If it kick out a batch then changet the water valve. If it fails to make a batch then replace the ice mold thermostat or get another ice maker.
Mar 13, 2009 | Refrigerators
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Maytag MSD24GR ICE MAKER
you need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Aug 09, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
